03-02-2021, 04:31 PM
Door Lock
I decided to replace the door lock with a lock from RVLOCKS.com The reason I replaced it, is I was having trouble with the factory installed lock where sometimes it would not lock and a couple of times it would not unlock while we were inside. When I took the screws off the back plate plastic parts fell out of the lock. There is a youtube about fixing this problem but I decided to replace the entire lock. The pictures are the broken parts that fell out and the replaced door lock.
2017 Forest River FR3 32DS
Retired Navy
Retired IT Professional
03-02-2021, 05:33 PM
Same here, I replaced mine only because I wanted an RVLock, but upon taking the original lock out plastic jiggly bits fell out all over the place
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah Lithium Batteries, 2000 Watt Inverter, 40A DC/DC Charger, Sumo Springs, Roadmaster Steering Stabilizer, Blue Ox Trac Bar, Truma On Demand Water Heater, NVIDIA Shield TV,
03-02-2021, 07:48 PM
Degree of difficulty in replacing?
03-02-2021, 08:27 PM
I did have to trim the bottom edge so the new lock would fit and align properly. The hardest part was getting the two lock post to line up with the handles used to turn them. Other than that it was fairly easy.
Retired Navy
03-02-2021, 11:14 PM
What year/model did you install on? I have a 2018 32DS that I'm looking to put a keyless lock on but wasn't sure if the RV Lock would work.
03-03-2021, 04:05 AM
I installed a RVLock on the door & RVLock Key Cylinder for Compartment/Baggage doors all keyed alike.
03-03-2021, 08:07 AM
I have a 2017 32DS and purchased a right side door lock. The way to tell if you need a left side or right side is, stand outside the RV and look at the door. If the hinges are on the right side you need a right side door latch.
Retired Navy
03-03-2021, 11:48 AM
Installed mine took longer than expected, only because of the cutout opening on the FR3 when you removed the original lock was not 100% plug an play fit with the RVLock.
I have to shave about 1/8th of an inch of material to allow the RVLock to fit, then aother 1/8th of an inch at the deadbolt door plate on the trim. I dont blame RVLock. A little with FR with their measure once cut once mentality. Wasn't too hard just took longer than 10Min. (about 45 min from unbox to program)
03-03-2021, 04:30 PM
Interested in knowing what you used to shave the door material with and what did you use to shave the metal door plate? On the door material was it the inside of the door or the outside?
Ron & Betty, Ormond Beach FL
New 2019 FR3 30DS
2013 Entegra Anthem---SOLD
03-03-2021, 07:49 PM
Originally Posted by brents
what year/model did you install on? I have a 2018 32ds that i'm looking to put a keyless lock on but wasn't sure if the rv lock would work.
2019 fr3 33ds
03-04-2021, 06:08 PM
I went with the V.4 model for a class A
Retired Navy
03-04-2021, 06:10 PM
I purchased an oscillating multi tool from Harbor Freight tools and a straight blade.
www.harborfreight.com/variable-speed-oscillating-multi-tool-63113.html
Retired Navy
03-04-2021, 06:11 PM
Class c/a right hand rvlock keyless entry door handle
03-04-2021, 06:16 PM
I bought a couple of Carbide Rotary File Cutting Burs Tools
Use it in my drill, I felt that way I could control how much or little material I needed to cut away. Using anything bigger made me nervous, I could slowly whittle away material. Used it on both the door and metal jam
https://www.amazon.com/Carbide-KangT...01N6MVSJY?th=1
