Old 05-19-2020, 04:50 PM   #1
Drivers side camera quit working
I have a 2015 FR3 30 DS. On a camping trip this past weekend, my drivers side camera quit. The passengers side and back camera still work fine. Several FR3 owners said to check the connections behind the radio panel, which I have now done, but, found nothing loose. Does anyone know the name/brand of this camera system and/or have you had to replace one of your cameras?
depmgt is offline   Reply With Quote
Old 05-19-2020, 06:14 PM   #2
leisurelarry's Avatar
These are the part numbers from Forest River. I also have a 2015 30. You must take these part numbers to a local dealer and order them from them you cannot buy them directly from Forest River.
leisurelarry is offline   Reply With Quote
Old 05-19-2020, 06:25 PM   #3
Thank you. If you replaced a camera, how hard was it to do?
Old 05-19-2020, 10:23 PM   #4
Have not yet, but doesnít look difficult. I removed from the side of coach and that was fairly easy.
Old 05-20-2020, 06:20 AM   #5
bubbles's Avatar
Of course you have verified it is a bad camera by connecting it to one of the other camera inputs to the monitor.
Old 05-20-2020, 09:45 AM   #6
I donít know about depmgt, but mine is waterlogged and appears that way on the monitor.
Old 05-20-2020, 10:19 AM   #7
bubbles's Avatar
If you saw water on the monitor it was not inside the camera it was in front of the camera lens. There typically is a screw on front lens cover (with "O" rings) with clear plastic lens and water will sometimes get inside that lens cover. The camera itself is a sealed unit. It may be similar to this. I think. Of course could be completely wrong.
Old 05-20-2020, 05:47 PM   #8
You may very well be correct! Iíll have take a closer look. It appears to be clearing up with the warmer weather.
Old 05-23-2020, 12:19 PM   #9
The reason the camera quit is quite possibly that the wiring that plugs into the multiplexer has come loose.
The multiplexer is located behind the center console between the 2 front seats. When I had my FR3, the plug would come loose. It has 3 inputs, one for each camera
Just press it back in and you may have solved the problem.
Here is a picture of the multiplexer Forest River uses.
Name:	RVS-501N multiplexer.jpg
Kentucky Bob is offline   Reply With Quote
Old 07-01-2020, 02:12 PM   #10
MV1 Cameras From Rear View Safety
The cameras on the 30DS are from Rear View Safety and when you order them let them know you need the long bolt version of the camera. They are about $119 each and install pretty easy. Just google Rear View Safety in NY.
JJackson is offline   Reply With Quote
Old 08-11-2020, 07:57 AM   #11
Neilthepilot's Avatar
There are links on this previous thread.https://www.forestriverforums.com/fo...ra-202701.html
2019 Fr3 30DS
CHF, Koni Shocks, 4K inverter, SK1000 Dish, Winegard Connect 2 4g, TST TMPS, Snap Pads,Flow Rite Battery Filler................
https://katskamper.com
Neilthepilot is offline   Reply With Quote
camera
