05-18-2021, 06:23 PM
Ford Recall on 2021 FR3
I've discovered that our 2021 FR3 34DS has a recall notice from Ford. It has to do with possible replacement of the bearings for the rear axle on the 2020 F53 chassis. My local Ford truck service manager said they'd want the rig for three days in case parts have to be ordered.
You can check whether you are affected by entering your VIN at https://owner.ford.com/tools/account...e/recalls.html
Here's the text:
INADEQUATE REAR AXLE OIL FILL VOLUME
NHTSA Recall Number: 21V202 NHTSA Date: MAR 24, 2021 Ford Recall number: 21S17
Status:11 - RECALL INCOMPLETE
Recall Description: INADEQUATE REAR AXLE OIL FILL VOLUME
Risk to Safety: IN THE EVENT OF REAR AXLE OR DRIVESHAFT FAILURE, CUSTOMERS MAY EXPERIENCE LOSS OF VEHICLE MOTIVE POWER, LOSS OF TRANSMISSION PARK FUNCTION, AND LOSS OF PARKING BRAKE FUNCTION, INCREASING THE RISK OF A CRASH.
Remedy Program: OWNERS WILL BE NOTIFIED BY MAIL AND INSTRUCTED TO TAKE THEIR VEHICLE TO A FORD OR LINCOLN DEALER. ALL VEHICLES WILL BE INSPECTED FOR LUBRICANT LEVEL AND EVALUATED TO DETERMINE IF BEARING REPLACEMENT IS NECESSARY. THERE WILL BE NO CHARGE FOR THIS SERVICE. FORD IS EXCLUDING REIMBURSEMENT FOR COSTS BECAUSE THE ORIGINAL WARRANTY PROGRAM WOULD PROVIDE FOR A FREE REPAIR FOR THIS CONCERN. FORD WILL FORWARD A COPY OF THE NOTIFICATION LETTERS TO DEALERS TO THE AGENCY WHEN AVAILABLE.
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
06-06-2021, 11:12 AM
Mine is going in next week for the service. Takes about a day for them to do it.
06-06-2021, 11:35 AM
Best of luck! I’m being told it could take as long as three. One dealer said that their service bulletin tells them that replacing the bearings is optional (which is not what our letter said).
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
06-06-2021, 03:01 PM
I set up an account here. Let them keep an eye on my VIN and tell me if anything else comes up. I think I barely squeezed under the build dates on this one though.
https://owner.ford.com/index.html#/
10-31-2021, 01:31 PM
The recall work was done at the end of August. Unfortunately, the "tone ring", which is part of the sensor for the ABS, was damaged. Of course, those parts are on back-order and the Ford dealer is unable to get a commit date from Ford as to when it will order. As a result, we can drive the RV, but we're without ABS, traction control, and cruise control.
This isn't an FR3-specific issue. Reading other manufacturer forums, quite a number of people people who had the recall work done had issues with the tone rings after the fact.
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
10-31-2021, 01:32 PM
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
11-15-2021, 08:55 AM
FR3 recall
My local Ford dealer sent me home with instructions to not drive the RV. They are ordering parts and will notify me when they arrive. Between the generator issues and now this my FR3 has gone from weeks out of service to months.
Stan
2021 FR3 34DS
Whistling Duck Winery
Weimar, TX
11-15-2021, 12:00 PM
Ugh! Interestingly, my local Ford service manager told me it should be OK to drive.
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
11-16-2021, 01:29 PM
My dealer told me to drive it until the parts came in ( which they did this week). I explained that I was taking it on a 5,000 mile adventure and he still said to drive it. We returned without any issues with the axle. It’s currently in for correction.
FR3
Pushed by a Red Rubicon
11-16-2021, 05:45 PM
Best of luck! If the Ford truck place is a fair drive from your home, you may want to ask the service manager to drive it for five miles before telling you that it is ready for you to pick it up. It is anywhere between 0-5 miles when the tone ring problem disables my ABS, traction-control, hill-start, and cruise-control.
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
11-16-2021, 07:48 PM
They called and it will be ready tomorrow for pick up. I counted 5 other new Class A MH on their service lot getting the recall performed. Hopefully all will go well.
FR3
11-18-2021, 03:51 PM
Got mine back today from the dealer (Ricart Ford, Columbus) and all is great after driving it 35 miles. I mentioned the tone ring issue that some are having and the service manager admitted that they too have had a few problems but mine didn’t present any problems.
FR3
11-18-2021, 04:09 PM
That is awesome news!
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
11-21-2021, 12:02 PM
After reading everyone’s posts I decided to go ahead and drive my rig. Topped off the fluid, still waiting on parts delivery at Ford.
Stan
2021 FR3 34DS
Weimar, TX
11-21-2021, 12:59 PM
When I drove mine on the 5,000 mile, 6 week adventure before correction, I was flat towing my Rubicon (4,850 lbs.) out west through Arizona, Nevada, Utah and Colorado climbing 5, 6, and 8% grades with no issues. If the differential fluid is at the proper level you should be good.
FR3
12-07-2021, 05:14 PM
Commercial Member
You can always enter your vin# at "www.safercar.gov" to determine if your coach has any outstanding recalls.
Tone rings, which are not necessarily related to the recall, are in a major shortage at the current time. If you're going to "drop your unit off" at a Ford dealer for tone rings I would make sure that they have them in stock or at least an anticipated delivery date. I know that there are units out there from August that are still waiting on tone rings and Ford isn't giving dealers an ETA on when they will receive them.
As far as the actual recall goes relating to the rear axle and the possibility of insufficient axle lubricant- Ford has stated that if your vehicle is effected by the recall to take your unit to a Ford dealership to have it checked. If your local dealership has bearings in stock they will replace them and re-fill the axle. If they don't have them in stock, they will at least refill the rear axle until they can get the bearings. When they do get the bearings they will drain the system, install new bearings and fill with fresh axle lubricant. Ford says that if you at least have your fluid checked at an authorized dealership, and filled if necessary, that the coach is safe to drive until you can have the bearing replaced. They've found that only a small percentage of units with low axle fluid actually had any bearing damage, but the longer a coach is driven in that state the higher the probability that it will occur.
12-16-2021, 11:59 PM
I went to a lemon law firm, they notified Ford, and a week later the local service center notified us that the tone rings had arrived. It could be coincidental…
The tech drove it for 5 miles before turning it over to me. I drove it another 15 miles with no issues. Hopefully, this problem is now in the rear view mirror.
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
12-17-2021, 03:56 PM
Thanks for sharing this recall info. I entered my VIN and no recall was found. I checked with local Ford dealer where I get my oil changed and he informed me that the chassis is actually a 2019 model regardless of the 2020 listing which is for the coach, not the chassis. Learn something new each day. Wish you safe travels.
2020 FR3 34DS, Blue Ox Avail, SMI Stay-In-Play DUO Braking System, Tire Minder TPMS-i10-10, Lippert Friction Door Hinges, GPS Rand McNally OverDryve 7RV, Safe-T-Plus, Sumo Springs Front & Rear, Sway Bar Front & Rear, Roadmaster Stabilizer, Soft Start both AC's, WACO AC Silencer, Frig Defender ARP Control v5.11 + 2 Fans. 2012 Cadillac SRX Luxury
01-29-2022, 11:02 AM
ford recall
We had our recall repair scheduled for early December, they cancelled and pushed back to March 29 because they can't get the parts. First I was told it was the seals now it's the bearings. I called Ford Motor Company and they were nice but really didn't know anything either. We got the recall notice in September bought Georgetown in June, but the original recall on the Ford site is March 24, 2021. Our RV dealer should have known about that and never sold it until it was repaired.
