I have a 2019 FR-3 33DS, the led acid batteries that came with mine were horrible. Even turned off if you dont have some form of trickle charge they wont stay 100% charged even with the disconnect switch flipped. However, being completely dead after only 2 days seems excessive.
IMHO if you an afford Lithium pick up at least one 100ah battery that will be more efficient and essentially is like 2 lead acid batteries. (the more the merrier if you can I have 4 = 400aH) They are expensive but Battle Born does offer a monthly payment schedule to ease the pain .
If you want to stick with AGM/Lead Acid, yea Id say your batteries are spanked.
If you do get AGM/Lead acid you should also think about a small solar kit to keep the batteries charged while in storage. (assuming you're outside)
Lithium you dont need to keep on a trickle charge.
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
