FR3 2020 DS30 - Atwood Rooftop HVAC System
Hello,
Bought our MH new in 2020 from a dealer. Have been camping plenty of times and used the two HVAC systems (living room & bedroom) mainly AC. Today I realized I've never used the HEAT mode via the wall panel in the bedroom system, so I tried it and nothing happened. The wall panel display is on and with the selected buttons desired and temp set. No Heat pump activity! The system will work for all the other options: Cool, Dry, Fan but not for Heat. The living room system works as designed, no issues.
The Atwood manual that I have indicates that if there's a furnace button on the wall panel display then I have model AC-1511 which should provide heat. Seems like if you have the AC-1361 model then you have no furnace options.
Anyone else have this issue or any insight? I have reached out to my dealer's technical team asking them the same question, but wanted to also try this forum too. Thank you.
2020 Forest River FR3 DS30
2019 Chevy Equinox LT 2.0
Blue Ox Patriot II System
Smiling as we're Driving!
