Originally Posted by Travelbuff2019
Hello! One more try here before I get tech support. Three tv’s in RV. Outside, living room and bedroom. Hit or miss with clear connection at RV site. Direct Connected cable to BR tv and double channels plus digital, perfect picture! do not get that when connecting to RV. Some say check splitter...where is it in my RV? What connections in RV can I check? Tv’s do not pick up same channel...doing everything right, running channel scan...using antenna when cable connection is poor. Just need to understand what internal connections may be causing the problem.
Also, we cannot get living room tv off bracket no matter how hard we pull up. Can’t access those connections behind tv.
Can anyone help? Thank you! Jacky
first off if all connections are right, look behind tv in both rooms. look for button that is lit green or red. it would be where cable comes in. push itmake sure anntena is off and down,and sat., is not connected.
