The hose and cap inside the compartment are for pumping in antifreeze.
The low point water drains are below that compartment, underneath the camper. There are two capped hoses, one is from the fresh water tank, the other from the plumbing system (feeds the faucets). There is a third uncapped hose, the fresh water tank overflow.
Pull both of the capped ones and let them drain. After they drain, turn the three valves next to the water heater to bypass.
Put the caps back on under the camper and use water pump and the hose inside the compartment to suck antifreeze into the system, it will not go into the fresh water tank. It will fill the lines, so open each faucet in turn until you see antifreeze coming out.
Tada!
2009 FreeLander - Retired
2015 FR3 30DS - Retired
2023 Sunseeker 2440DS
Towing 2016 Chevy Sonic LT
