07-23-2016, 04:01 PM
#201
kansas, love that. what hardware u use. end of paracord pics
07-23-2016, 04:21 PM
#202
It was from Lowes, like the automotive drawers I think. A countersunk phillips w/washer was used on both locations. So far, I've just wrapped the paracord, tighten it down and trimmed the paracord. It seems like its holding just fine. Got the idea from another forum where they used a flat nylon strap instead.
07-23-2016, 09:33 PM
#203
awesome, thanks. well worth doing
07-24-2016, 12:33 AM
#204
Originally Posted by JBDALHB
We bought this folding table at a home goods store which has served us well for a year but I wanted something more permanent. So I ordered the ITC Sequoia table leg system including adding two cup holders. Works great and I'm happy with the results.
Sequoia™ Table Leg & Base System - ITC RV
I love this table idea . How high was it ? They come in different sizes thank you so so much
07-25-2016, 07:52 PM
#205
Hey Kansas
In the photo of the door stop cord I noticed you have more cords on your entrance door window. Is that for a removable black out shade?
07-25-2016, 08:45 PM
#206
Originally Posted by Technorick
Hey Kansas
Nothing gets by you guys! Kinda sorta, I cut out a reflective bubble wrap to slide behind the string that I strung. Just loosen up the screws slightly, wrap some string around the screw and torque them back down. Works good enough.
Might be better if you glue some small magnets onto the four corners of the frame, then have some black out cloth between another set of small magnets...food for thought. Good luck with whatever project your thinking about.
07-25-2016, 09:27 PM
#207
good one. i just used gorrila tape last weekend
07-26-2016, 10:07 AM
#208
[QUOTE=JBDALHB;1254337]We bought this folding table at a home goods store which has served us well for a year but I wanted something more permanent. So I ordered the ITC Sequoia table leg system including adding two cup holders. Works great and I'm happy with the results.
Sequoia™ Table Leg & Base System - ITC RV[/QUOTE
Nice add....
Hey what kind of devise mounts are those on the dash next to the console?...
I'm looking to mount my iphone somehow and I just bought a Garmin RV GPS and need to mount it someplace too...
I really like the idea you had on that little table.
2015 FR3 30 DS
1995 Wrangler
Miles 9100
Days Camped 74
07-30-2016, 02:28 PM
#209
07-30-2016, 08:40 PM
#210
I feel you KansasFR3. I just came in from the FR3 after completing the sanitizing of the fresh water tank again. I had to pour the Clorox solution into the hose (many times) to pump into the tank. Then I came in and read your post. ARRRGGG!!!! NOW! guess what mod I will be doing before I go through that again. Thanks for the tip.
2016.5 FR3 30DS AKA "Serenity"
Searching for that perfect spot with loving Wife & 2 mini dachshunds
08-08-2016, 08:13 PM
#211
Twojump36, it's the iOttie Easy Touch Pad holders for the iPhone and iPad Mini I drive with. I use The app Waze as my GPS on the iPad. These holders are great - even on the bouncy FR3 dash, they stay attached.
08-19-2016, 03:28 PM
#212
08-19-2016, 03:34 PM
#213
I also use the iOttie. Bounces like crazy, but stats attached. Waze is great.
Antone
2015 Forest River FR3 30DS - No Ragrets
Toad - 2011 Jeep Wrangler
08-22-2016, 08:51 PM
#214
Where did you go for a blue tooth controller outside? Pics
08-23-2016, 09:33 AM
#215
We purchased from a local dealer/installer - he was wiring up the extra cameras and sensors for us so had him do all of the speakers as well - but here is the unit we installed http://www.crutchfield.com/p_1369112...1643625&awdv=m and an up close of it on our coach this was installed with the bigger JL audio speakers and an amp - all was mounted and wired just under the tv housing where there is open space - all marine grade so water and impact resistant
08-23-2016, 09:37 AM
#216
I can have hubby take pics of wiring if you like (I'm clueless there) but speakers run to the main unit inside and can be used for movies/stereo etc like the originals they or can be switched for use by phone or other Bluetooth device using the BT receiver. We added a switch to dash so the speakers outside can play music from our devices and the inside can watch a movie or listen to diff music as well at the same time
10-01-2016, 03:36 PM
#217
More than I bargained for
Just completed following to 2014 FR3 31'
Convert to 50 Amp Serv.
3 /100 watt solar panels with controller
2000 watt inverter
2 6 volt batteries in series with 12 volt in parallel
Bogart Battery monitor
Second air conditioner
Have not changed out Generator / thus need to be land based to operate both Air units/ Not sure I will change this
Removed front couch/bed and booth/ Replaced with two small recliners and 2 person/desk table
Replaced/upgraded all speakers
Yes, all this was an adventure ! I will provide pictures
Pleased with result but not for the faint of heart.
Bear
10-04-2016, 07:21 AM
#218
Good luck !!!
10-10-2016, 01:23 PM
#219
kerber77,
how's the viair system working out?
11-30-2016, 01:29 PM
#220
per wife's request extra shelve in bath cabinet
dvd player in bedroom
