04-04-2015, 08:43 AM
FR3 Pictures of Mods
Please post pictures of FR 3 modifications here. We pick ours up next week and are already planning modifications, change fron a king bed to a queen for storage, that dash!!!
04-05-2015, 12:03 AM
I got mine 3 months ago and I've done plenty of modifications. Here my top 6. Hope it helps
-6) 42"TV where the previous 32 was
-5) 30 Amp to 50AMP upgrade
-4) adding 2nd A/C
-3) storage on bunk bed
-2) sliding BBQ outside
-1) Washer/Dryer
Enjoy
04-05-2015, 12:38 AM
Wow will be looking at some of these
04-05-2015, 12:39 AM
Did you also put a table between the chairs? I see flowers out of no where
04-05-2015, 12:30 PM
HAPPY WHEN RV'ING
ssaavedra: Would love to know what you used for the sliding bbq. And any info on how you did it would be great. This slider is a great idea!!
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
04-05-2015, 05:28 PM
Didnt realize that wqs a sliding barbecue.. Hmm id love to know the dirt little secrets
04-05-2015, 09:38 PM
I bought a small bench to put on the middle of the copilot space, trying to utilize as much of the RV as possible.
04-05-2015, 09:42 PM
Thanks, is so useful. I got Coleman BBQ which had the perfect dimensions for that spot, used a Y has connector coming out of the Gas tank and brought it all the way to the back of where the slide is, opened a small hole on the corner to pass the line. The slider is a simple plywood and rail system with a small metal top to not cook the wood with the heat.
04-06-2015, 12:59 AM
And this bbq wont burn the side.of the rv
04-06-2015, 02:07 PM
Does the TV still swing out & did you have to modify the mount?
04-06-2015, 04:26 PM
The TV still swings out without a problem, BBQ hasn't heat up the sides or anything, I've used it 5 times successfully. I also pulled an extra line from the Y connector to connect an external burner, such as a Spanish paella burner in my case. Just another good easy idea.
04-06-2015, 06:27 PM
30 to 50 amp
Originally Posted by ssaavedra
what do you have to change to go from 30 to 50 amp pictures please.
Carl & Bette
2018 Leprechaun
NEW YORK
04-10-2015, 02:16 PM
Ok can you tell me which fittings i need and where you attqched the hose for the barbecue
04-10-2015, 02:18 PM
Here
04-10-2015, 02:21 PM
Is this what i need. Where would i attqch
04-10-2015, 02:23 PM
So we attaxh here
04-19-2015, 08:29 PM
Some needed items in bedroom.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
04-19-2015, 08:38 PM
Fpo1123 those are kick ass! Did you make them your self? How much would you charge to make me a set or for a copy of your plans.? I'm not much for wood working.
JeNNY (2015 FR3 / 30DS)
2000 Jeep TJ Moab Rock Crawler
2013 Jeep JK
04-19-2015, 08:48 PM
I have always said if I helped build the Ark there wouldn't be an animal alive on earth today. I just bought some wood and stain and tried. I knew I could make then 6 inches wide and went from there. I cot the legs out of the same piece of wood and attached them and then cut cross braces and sanded and stained. I think the wife thinks I can build real things now...
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
04-19-2015, 08:53 PM
But if you like I will measure and send it and the stain color and brand to you. It was simple.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
