Old 10-21-2020, 02:36 PM   #1
FR3 Slider cable
Iíve got a 2018 FR3 29DS I noticed when I extend the sliders out (bedroom & sofa) that all 4 cable are loose. Do I need to tighten them? If so how do I do that. Appreciate any assistance.
Llee3 is offline   Reply With Quote
Old 10-21-2020, 02:52 PM   #2
hdjimmi's Avatar
I could be wrong but if u are checking the cables while it is out on the outside cables they will be a bit loose as those cables pull it back in??
Retired and loving it
hdjimmi is offline   Reply With Quote
Old 10-25-2020, 09:05 AM   #3
Th cables will need adjusting. Ive done mine twice in the last 6 years. Since i leanred how to replace the motors when they failed (actually gear box but easier to do the whole motor) was not bad. There is a good video out there from lippert i believe.
KY25DS is offline   Reply With Quote
Old 10-25-2020, 02:20 PM   #4
rk06382's Avatar
I had to adjust my sofa slide cables and found a one of the white foam blocks was off. It allowed the cable get loose. Make sure all the white foam are on your cables.
Below is a youtube on adjusting the cables. Derryl Farar explains the slide components & motor/gearbox replacement.
Also see my thread: Stuck in my Driveway with a dead living room slide motor
I posted photos on how to remove the sofa trim.
Robert
2018 FR3 28DS | Boondock 90% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
cable, fr3, slide
