Old 03-22-2023, 04:40 PM   #1
Gas Water Heater On = Propane Smell Inside RV
Water heater model: Suburban SW6DE
Obviously, in electric only mode, there's no gas smell.
When the gas switch is turned on, water heats up faster (as expected) but there's a smell of gas / propane inside the RV and it seems to be coming from the furnace ducting... It's quite strong and noticeable (primarily in the bathroom and is made worse when the ceiling fan is on, regardless of whether the windows are open).
Could unburned propane somehow be pulled through the furnace?
The only recent events are that our LP tank was refilled and there was some sub-freezing overnight temps (furnace was turned on and off as needed). Not sure if either of those have anything to do with this issue.
2021 Forest River FR3 33DS
2019 Jeep Cherokee Trailhawk
besweeet is offline   Reply With Quote
Old 03-22-2023, 06:08 PM   #2
Kanadian Kamper
kenandterry's Avatar
The smell of propane in an RV is serious business.
You need to have this looked at immediately.
If it’s that obvious, I’m also concerned that your LP detector isn’t sounding.
That’s also a serious concern.
Please get this looked at ASAP.
Ken and Terry
kenandterry is online now   Reply With Quote
Old 03-22-2023, 06:47 PM   #3
The smell isn't making its way through the whole RV but rather situated in the bathroom (the ceiling fan is likely preventing it from getting everywhere).
Definitely only coming through the furnace vents even if the furnace isn't on.
Old 03-22-2023, 07:46 PM   #4
I've used this at home to find a leak.
https://www.homedepot.com/p/HOME-FLE...-001/301876827
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 03-23-2023, 02:17 PM   #5
It's a motorhome
Since the odor only occurs when the water heater is on, the leak must be occurring at the solenoid valve (electromagnetically-controlled valve) that controls gas flow.
This means that the area of leakage is limited to the valve and the short piece of tubing and orifice beyond that. On Page 30 of the attached manual, you will see:
  • 36 Valve
  • 56 1/4" Loxit Nut
  • 37 Outlet Manifold
  • 55 1/4" Loxit Nut
  • 26 Burner assembly with orifice
These items are pretty much in direct view when you open the (outside) door to the heater.
Put about a teaspoon of dishwashing liquid in a coffee cup and fill it mostly with water (proportions aren't critical). Stir it to a healthy froth. Use a small paint brush to paint the solution onto all the areas listed above, looking for bubbles. If you can smell gas, the leak will be very easy to find--lots of bubbles.
Also check that the burner assembly (26) end is properly positioned in horseshoe clip 53.
This is not rocket science and doesn't need an exotic leak tester.
Larry
Larry-NC is online now   Reply With Quote
gas, heater, propane, smell, water, water heater
