I notice a number of people have mounted soap dispensers to shower, bathroom wall and kitchen wall. I am new to being an RV owner and we are about to take delivery of a 2018 FR3 30DS. The walls seem very thin. How are people mounting the mounting plates?
We use Command Strips for bathrom areas, or the indoor/outdoor kind. They also make soap holders and mounting strips, but I didn't like them so we bought one that matched our rig and used the Command strips.
There are other indoor/outdoor double sided mounting tapes out there and most of them work equally well.
You would be surprised how good those Command Strips hold on even painted walls... smooth surfaces even better, with no damage to the wall surface when you want to take it down.
I took down all our window valances this weekend and replaced with curtain rods. I just made sure any new screws were smaller than the screws in the L brackets the valances screw to were mounted with. Drilled a small pilot hole to get the new screw started.
In other than damp locations, I have had good luck with pop rivets over the years. Just make sure you use a rivet that expands on the backside of the paneling and you want a permanent mount.
Mark & Heather
Mountain Falls, VA
Here's our kitchen area - with mounted spice rack + magnetic knife holder. Also removed the TV and built some cabinet doors with white board insets - the kids love waking up each day to see what the plan is, where we're heading and what we're doing -
