11-06-2016, 10:48 PM
More problems
28 fr3
11-06-2016, 10:51 PM
Has anybody else lost all the water out of the fresh water tank
Forest river has a fix however they don't tell the consumer until it ruins yet another weekend
11-06-2016, 10:53 PM
Many of us have had that problem. I left an ice skating rink on the street in front of my parents house in Omaha last winter. 😝
2015 Georgetown 329DS
2014 Chevy Equinox
11-06-2016, 10:57 PM
Have you also had 3 windshield leaks
It's raining super hard
Pretty sweet
11-07-2016, 07:55 AM
Sounds like your working through issues on a new unit. Both of those issues are common. Use the search bar on the FR3 forum and you'll find a bunch of duplicate topics. The water overflow is because the tank becomes pressurized after you fill it up and ends up siphoning itself once it overflows. Some have had success with adding additional length of hose to form a coil or two before going out the bottom. Others have added a radiator flush T inline with a small hole drilled in the cap to vent the tank.
https://www.amazon.com/Dorman-47153-...radiator+flush
On the windshield, I thought the newer units went with a windshield gasket and solved most of the issues. Guess not. Most have given up with a dealer for a fix and will recommend you take it straight to an actual windshield repairman.
Mike
2015 FR3 30DS
11-07-2016, 12:02 PM
Good point on both issues. I've had them both and both were fixed, neither by the dealer.
2014 Chevy Equinox
11-07-2016, 01:02 PM
HAPPY WHEN RV'ING
Like KansasFR3 mentioned, you need to put some type of "P" trap in the overflow hose coming from the top of the tank. What happens is when you fill the FW tank and start driving, it creates a vacuum suction and will siphon the water out. Many different methods have been used to remedy this. I just used 1/2" pvc, made a "P" trap and added it inline. Or, if you have enough hose, put a coil or 2 inline. Problem solved....
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
11-09-2016, 09:37 PM
New Member
Doesn't the over flow come off the very top? I wondered why that happend to mine the first time I filled the tank.
11-09-2016, 10:05 PM
HAPPY WHEN RV'ING
Yes it does. Happened to us when we brought our FR3 home from the dealer. The dealer had no idea why the water loss would happen on such a new unit. I was not a happy camper with them. I called FR and talked to one of the reps. He told me about the "P" trap fix. He wanted to send parts to the dealer. I respectfully declined and told him that dealer would never see this coach again. I bought the parts as he described and did the repair myself. BTW, FR found me another dealer closer to me in case I needed any warranty work done.
11-09-2016, 10:42 PM
The p trap can cause a blockage possibility of collapsing the tank by blocking the air flow to the tank
11-10-2016, 01:29 AM
HAPPY WHEN RV'ING
Sorry. This is incorrect. There will still be an open line even with the p trap or loops in the line. No blockage will occur unless a big chuck of debris gets in the line. Highly unlikely. The p trap stops the vacuum effect that would create a siphoning of the water.
