Old 05-13-2024, 07:02 PM   #1
My Lithium Upgrade 2018 Forest River FR3 30DS
Ok Boys/Gals... This is my Lithium upgrade. Good or Bad, here it is...
Objective: To install the lithium battery, Lithium Battery Isolation Manager, and Lithium Converter in our 2018 Forest River FR3 30DS.
Battery: EPOCH 460 https://www.epochbatteries.com/produ...-victron-comms
Size and location: The battery box was modified to fit the larger 460ah battery in the coach battery location. We modified the back wall to accept the extra length.
Wiring: RV Custom Products SDC-107 Battery Control Center https://rvcustomproducts.com/sdc-107a
The battery is also 12V and a Lithium Battery Isolation Manager LI-BIM 225 was installed.
Anyone needing the older 12V distribution manufacturer has a tech support that can explain this process better. We candidly by-passed and used their connections to incorporate the BIM 225.
RV Custom Products (562) 921-8353 (They are open from 7AM to 2PM M-F): https://rvcustomproducts.com/sdc-107a
Lithium Battery Isolation Manager LI-BIM 225: https://battlebornbatteries.com/wp-c...uick-Guide.pdf
https://www.precisioncircuitsinc.com...i-BIM-Rev1.pdf
Converter:Progressive Dynamics PD9360V https://www.progressivedyn.com/produ...360-converter/
Instructions:https://www.progressivedyn.com/wp-co...6A-english.pdf
This should be the easiest to swap and is in the left rear compartment. There are instructions on setting it up for Lithium and is a matter of changing a slide LED to a certain color (Blue) by pressing a button with a pin tool on the side for three seconds until the correct color appears.
We installed a new 30amp 12v connection for a inverter than can run our Starlink system. Anyway, it can be done and hope this helps.
BTW, no solar yet but that is phase 2.
ID:	299755   Click image for larger version
ID:	299756   Click image for larger version
ID:	299757   Click image for larger version
ID:	299758   Click image for larger version
ID:	299760   Click image for larger version
Kylehove is offline   Reply With Quote
Old 05-14-2024, 04:54 AM   #2
rk06382's Avatar
Looks good.
I have been on Lithium since 2018.
I modified my SDC-107A BCC for Battle Born Lithium batteries in 2019.
How to adjust SDC-107A BCC for Battle Born batteries
I moved my negative chassis battery wires to a Victron BMV-712 shunt. The positive battery chassis cable goes to 500a switch & a Red bus bar.
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 05-15-2024, 02:34 PM   #3
So awesome! I haven't had to plug it into 110V since I installed it.
Old 05-16-2024, 11:32 AM   #4
rk06382's Avatar
I only plugin at home to run the AC & keep the batteries ready for the next trip.
A post from 2021:
Originally Posted by rk06382 View Post
Just remember whatever you do is a custom mod. It will be your job to become an expert of your system. You will need to be able to troubleshoot & redesign improvements.
That is why I believe the Victron BMV-712 is an required to know your SOC. I can check the SOC when the FR3 is parked in my driveway from living room recliner.
Good luck with your Lithium upgrade.
Lithium is freedom to boondock.
Eagle Summit. Sept 12, 2021
We saw a herd of Caribou on an August trip to Eagle Summit.
Attachment 266155
Sunset from dash cam. The GPS location is at the bottom of the picture.
Attachment 266156
We will return next year.
Robert
forest river, fr3, upgrade
