Old 09-15-2018, 04:10 PM   #21
leisurelarry's Avatar
Originally Posted by OldGunny View Post
Something else I JUST learned while prepping the RV for a road trip (Disney World next weekend). The mirror that is situated in the cab so the driver and copilot can look at each other, is in there loose. Mine can easily be moved around (safety hazard IMO). It is also a possible source of rattles while driving.
Suction cup, hot glue gun or velcro... probably both.
Mine came loose almost immediately in my 2015 30DS. Found it to be useless at any rate. Taped it entirely and broke it out in one taped up piece. Stained the lumber underneath (bottom of overhead bunk) to match the rest of the trim. More room to hang pictures of my grandchildren.
leisurelarry is offline   Reply With Quote
Old 09-15-2018, 04:15 PM   #22
Great idea! I will have to remember that for when/if I have grands!
OldGunny
2016 FR3 30ds
OldGunny is offline   Reply With Quote
Old 09-15-2018, 05:08 PM   #23
There was a gob of dried up black adhesive at each corner of the mirror. Only stuck to mirror .
Old 09-18-2018, 04:16 PM   #24
Any thoughts or ideas for the screen door? Mine constantly rattles at speeds above 35mph.
ptrei is offline   Reply With Quote
Old 09-18-2018, 04:40 PM   #25
The only thing that comes to my mind is trying the weather stripping for a house door... only use the stuff that has adhesive on one side to stick to the inside door frame.
OldGunny
2016 FR3 30ds
Old 09-23-2018, 12:16 PM   #26
TLAK's Avatar
Add some little stick on felt furniture feet to any area that is loose when the doors are closed.
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 11-20-2018, 08:10 PM   #27
Ptrei, saw you post from Sept, you may not get this but it may help someone. There is a metal plate at bottom of door, width of door and about 6"? high, right above the door sweep. Close the door and lightly tap the door and you may hear a rattle down there. I put additional screws in perimeter and problem solved.
cariboo camper is offline   Reply With Quote
Old 11-20-2018, 08:45 PM   #28
Have a look at some of my posts maiden voyage from a couple days ago.
Iankerr is offline   Reply With Quote
Old 11-20-2018, 08:51 PM   #29
The wind comes in from the heater.
The Windowes air movement is because the foam around the dash doesnt extend to the window. Also there might be a larger hole were the defrost vent is cut into the dash. The front doors rattle until you weatherstrip them and the mesh rattles until its secured. Most of the wind noise comes through the heater
Old 11-20-2018, 08:53 PM   #30
I used chair felt but another idea was silicone it
Old 11-21-2018, 09:37 AM   #31
Arvee Pilot
Old Oregoner's Avatar
That's what I used on my screen door. It's starting to buzz again, as the weatherstripping has gotten compressed. Time to add more!
2019 FR3 30DS
Toad: 2010 Explorer Ltd
Old Oregoner is offline   Reply With Quote
