Old 06-28-2024, 07:10 PM   #1
Parking brake
My 2020 FR3 34DS has a parking break that will not engage enough to prevent the coach from moving on a moderate slope. Has any one done a cheap fix on this issue of a Ford F53 chassis? Is it possible to adjust the tension of the parking break cable? Any help would be appreciated. Thanks in advance.
Don
LargoII is offline   Reply With Quote
Old 06-28-2024, 07:33 PM   #2
Oaklevel's Avatar
Not familiar with your unit but brake cables are normally adjustable cables.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Lillie Boxer Mix (RIP)
Old 06-28-2024, 08:44 PM   #3
Thanks, now I just need to know where and how.
2020 FR3 34DS
Sumo Springs, Koni Shocks, Safe-T-Plus, 5-Star Tuning, Super-Steer Steering Package and front and rear Sway Bars and Trac Bar, Centramatic, Soundown sound proofing, Kenwood DNR1008RVS, and Villa Capitan's chairs.
Old 06-28-2024, 08:52 PM   #4
Go to YouTube and do a search. Bet you'll find a video there.
Bob
Bob K4TAX is offline   Reply With Quote
Old 07-01-2024, 06:53 PM   #5
YouTube
Thanks for the suggestion of YouTube videos. I did find a few and they were mostly disappointing, but they did teach me the how of it. It may take me a week or two to make my attempt at adjusting the break but I'll let you know how it goes.
Thanks again!
2020 FR3 34DS
Old 07-03-2024, 11:49 AM   #6
RVwino's Avatar
Don
I thought that if the coach is in Park, then it won’t roll. If that’s true, the one exception is if your rear wheels are up in the air, which most RVers want to avoid.
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
RVwino is offline   Reply With Quote
Old 07-03-2024, 11:52 AM   #7
But isn't the parking brake applied to only the rear wheels? I seem to think so. Agreed, NEVER get the rear wheels off of the ground.
And if you put the transmission in PARK and the vehicle moves downhill more than 3" or 4", there is a transmission issue.
Bob
Old 07-03-2024, 12:16 PM   #8
RVwino's Avatar
That’s what I understand, as well.
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
Old 07-03-2024, 07:40 PM   #9
My issue was, and still is, that I stopped on a moderate slope of our driveway, engaged the parking break and then put the gear selector in park with all wheels on the ground. My FR3 34DS moved forward a little bit. Don't know how many inches. The next day I started the engine with the parking brake still engaged and my foot on the brake. I moved the gear selector into reverse. An audible and bodily BOOOINGGGG!!! was heard and felt as the transmission pin released under pressure, then I was able to back up. If the parking break had fully engaged the transmission parking pin would have released easily with no sound or vibration as I engaged reverse. So, it's the parking break. Our FR3 is now on nearly flat ground at the top of our upper drive. The entire fam damily is coming to our vacation home--now retirement home--for the 4th holiday weekend and week there after and more. Then we make the final move here furniture and all. Consequently, I won't have time to try and adjust the parking break until sometime in August, cause we don't plan to travel again until mid to late September. Still, I'll let you know if the cable adjustment works or fails.
In the meantime I hope you all have a great 4th of July celebration and/or family gathering and don't melt in the heat!
Don
Oh, and for RVwino there will be wine but a lot more Tanqueray & tonics!!
2020 FR3 34DS
Old 07-03-2024, 07:55 PM   #10
RVwino's Avatar
I hope you have a wonderful 4th, as well!
P.S. There’ll also be some Anejo.
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
Old 07-03-2024, 08:01 PM   #11
Yep and as I stated, the slack in the differential and U joints and transmission will allow the vehicle to move forward a few inches once Park is engaged and the foot brake is released. This puts pressure on these items. Correctly, I first engage the parking brake, shift into Park, and stop the engine.
Starting with the foot on the brake, and starting the engine does not relieve the pressure on the mechanical drive train. Yep, it will make some noise as the drive train releases and tightens up in reverse.
I'm not sure I would expect the parking brake to completely hold the heavy vehicle, depending on the angle, unless correctly applied. Would be nice and comforting if it did. Yes, likely adjustment of the cables and perhaps the shoes on the rear is necessary. Usually, the shoes are self-adjusting but this requires specific actions to accomplish such. Read the vehicle manual on this point.
Bob
Old 08-17-2024, 11:57 AM   #12
The parking brake gets adjusted like trailer brakes, thru a slot in the back.
Be very carefully adjusting it. If to snug, the brakes drag, overheat and burn the paint off the drum, along with the shoes.
Lots of complaints of this happening.
Twinboat is offline   Reply With Quote
Old 08-19-2024, 10:00 PM   #13
Thanks for your input. Having just retired and moved into our not-fully-finished new home in KY, I've been too busy with matters at hand to attempt a fix. I originally thought it might take a couple of weeks but the reality is it may take a couple of months. Who knew that retirement could be so busy!
2020 FR3 34DS
parking
