TV can be, it needs to have the inverter turned on (assuming yours has one)
Your antenna needs to be tuned on (there is a switch on the side look for the king Jack on the celling) more blue lights the better, and a push switch above the sink in the cabinet. Once you turn the antenna on you will need to go into the menu setting of the TV and perform a Air Scan for channels.
Radio, I not sure how yours is set up, there is a switch right underneath that says Radio, toggle it one way an the radio will turn on.
I have 2019 FR3 33DS
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
