Old 06-17-2021, 09:51 AM   #1
Question about tv/radio play without key
Hi, I'm new to the forum and my 2018 used fr3 30ds.
My question is can I get the radio or TV to play when I'm parked? Or does the key have to be in the ignition and e-brake on?
I did search and couldn't find anything here.
I'm sure I will have many more questions as time goes by.
Thanks, Dan
Dburr is offline   Reply With Quote
Old 06-17-2021, 11:58 AM   #2
robo44's Avatar
TV can be, it needs to have the inverter turned on (assuming yours has one)
Your antenna needs to be tuned on (there is a switch on the side look for the king Jack on the celling) more blue lights the better, and a push switch above the sink in the cabinet. Once you turn the antenna on you will need to go into the menu setting of the TV and perform a Air Scan for channels.
Radio, I not sure how yours is set up, there is a switch right underneath that says Radio, toggle it one way an the radio will turn on.
I have 2019 FR3 33DS
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30 [/B]
robo44 is offline   Reply With Quote
Old 06-17-2021, 11:59 AM   #3
bubbles's Avatar
I don't have an FR3 but in the GT there is a rocker switch on the center console the will switch the radio power to the coach batteries so it can be used without the ignition.
Old 06-22-2021, 09:44 PM   #4
hdjimmi's Avatar
Thanks, Dan
Our 2019 has a rocker switch on doghouse for radio. No key needed
Retired and loving it
hdjimmi is offline   Reply With Quote
Old 06-23-2021, 05:00 PM   #5
Thanks all. It works!
question, radio
