I installed an RVLock on my 2019 33DS, id recommend the same. However in my case it was not a simple removal of the old in insert the new. Not all FR3 are build identical as we all know, and i had to file down the lock opening on the door and the metal deadbolt slot. Just be prepared to spend some time measuring, filing or removing some door material. It also means you're committed as the old lock will not be able to be reinstalled.. Even with these known.. RVLock is the way to go. just be patent, tape things off, measure & install.
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
