09-02-2019, 10:21 PM
Remove Wheel Covers on 2020 FR3
It doesn't appear that the 2020 FR3 30DS has wheel covers. If it does, how do you get it off? It's in the way of getting a valve extension on the front facing rear tire.
09-03-2019, 07:51 AM
My 2019 FR3 has a special tool to remove the lug nut covers. This allows you to remove the wheel covers. I haven't tried it but the dealer showed us the tool during the PDI.
Lexington, SC
2019 FR3 30DS
2001 Jeep Wrangler TJ TOAD
09-03-2019, 07:57 AM
Kanadian Kamper
Two things.....
Look VERY CAREFULLY, and you’ll see three of the wheel nut lugs have markings on them that differ them from the decorative ones. These three are the real lugs to secure the wheel cover to the actual rim. You may even have a special tool to attach to the caps.
What is a front facing rear tire?
Ken and Terry
09-03-2019, 08:03 AM
Kanadian Kamper
Did you find a tool like this?
Ken and Terry
09-03-2019, 01:07 PM
Originally Posted by kenandterry
Two things.....
Dual tires on the rear; one behind the other. So, the front facing one is the outside tire.
09-03-2019, 01:22 PM
Two things.....
My lugs were to tight to remove with the 'special' tool. I had to use a 1/2" socket wrench to get it loose. But I did use the 'special' tool to put the lugs back on.
09-04-2019, 01:05 AM
You will have by now learned about the special tool and the three lug nuts. Suggest you buy a socket of the right size and a flex bar because the special tool is not strong enough to remove the lug nuts and probably does not offer enough leverage in any case.
You may have to remove the wheel covers to occasionally check lug nut torque and check air pressure etc. If you go to a tire dealership make sure the person doing the job knows how to remove the wheel cover properly.
I watched a young tire repair guy checking the torque on my unit scratch his head for a minute or so before I intervened and showed him how the cover is removed. He admittedly did not know.
2017 FR3 28 DS
09-04-2019, 01:08 AM
Front facing tire. Usually referred to as inside or outside rear dual, left side or right side.
2017 FR3 28 DS
10-17-2019, 05:22 PM
I'm still baffled as to how the wheel cover comes off these rear tires. There aren't 3 special lugnuts, they're all the same. Do you use the handle on the special tool to remove the wheel cover?
10-17-2019, 07:38 PM
Take a real close look. You should see that 3 are a little different. Look real close at the base of the lug nut cover. Put the socket over the nut and what you see should be different on three of the lug nuts.
Hope this helps, maybe yours are a different breed?
No, don't use the handle, actually you should get a socket of the right size 1- 3/16" don't try and use that tool they gave you as it will probably just break. I know on mine the 1-3/16 socket will not fit on the other 7 out of the ten hub cap lug nuts.
Might be a good idea to go to a tire shop or take a picture of wheel to them, better yet take a close up picture and put it on this post. If you figure it out let us know.
2017 FR3 28 DS
10-19-2019, 04:22 PM
Lfresin1,
When people tell you to "look carefully" at the lug nuts, they mean that you should be able to detect that most of them are fake, and are actually part of the wheel cover. You should be able to see that 3 of them are real lug nuts that can be removed (with great difficulty).
10-19-2019, 05:51 PM
Electric Impact wrench....no problem.
But do be careful and only use on the real lug nuts not the fakes that are part of the wheel cover.
10-23-2019, 11:52 PM
Two of the lug nuts had lines on them and no flange around them. Used the wrench that came with the RV and used a plastic bag to cover the lug nut. With a little careful pressure, it loosened and I could remove them by hand. The wheel cover comes right off. Thanks for all your help.
10-24-2019, 11:04 AM
Glad to hear you got it solved. Only two lug nuts?, usually three. Must have changed the design. If you ever need to have a tire changed make sure the person doing it knows how to remove wheel cover.
Thanks for posting back.
2017 FR3 28 DS
