Old 03-18-2017, 12:45 PM   #1
RV keyless door lock
I just tried installing an RVlock Keyless Class C/A entry handle on my FR3 30DS. The two large latch bolts on the new handle are too short and the old bolts have a different thread. Has anyone else tried to install this handle, and how did they resolve the bolt problem.
Jim Carter
2016 FR3 30DS
jimcarterhb1951 is offline   Reply With Quote
Old 03-19-2017, 03:33 AM   #2
We have one ready to install but haven't looked at it yet. .. will be following
colourful64 is offline   Reply With Quote
Old 03-19-2017, 06:07 AM   #3
What length and thread size do you need? Have you tried a hardware store? RV doors can vary by only a small amount on thickness,did you call RV Lock and ask about your bolts? Youroo!!
Old 03-19-2017, 11:33 AM   #4
The bolts I am talking about are not just regular bolts, they are the two large bolts that protrude from the lock and go into the latch plate on the left side of the door. Nothing you would find at a hardware store.
Jim Carter
2016 FR3 30DS
Old 03-19-2017, 11:41 AM   #5
Hope you have better luck than I did. Does your handle have 2 large bolts that go into the latch on the left side when closed? Those bolts when screwed all the way in as they should be, are too short, and will not allow the door to close.
Jim Carter
2016 FR3 30DS
Old 03-19-2017, 11:50 AM   #6
And yes I called rv lock in Utah, it was Friday at 1:30 pm and I got an answering machine saying it was after hours. I will try again tomorrow.
Jim Carter
2016 FR3 30DS
Old 03-19-2017, 12:16 PM   #7
any chance you can take a picture of what you are talking about and post?
Retired USAF
2018 FR3 29DS
Calls Space Coast of Florida home...but Roll Tide
bamagrad1992 is offline   Reply With Quote
Old 03-19-2017, 01:05 PM   #8
RV lock
Motorhome is back in storage, so I only have pics of the new lock. The 2 bolts that are too short are below the deadbolt and above and below the latch.
ID:	132191   Click image for larger version
Jim Carter
2016 FR3 30DS
Old 03-19-2017, 01:20 PM   #9
I had the same problem with mine. Company told me to get an Allen wrench and back them out a little ways. I did so but I also applied some Loctite to them when I put them back in. Has worked like a charm ever since.
cmalberto is offline   Reply With Quote
Old 03-19-2017, 01:26 PM   #10
Thanks I was concerned about using Loctite semi-permanent might back out and permanent would be a problem as things shift and wear on the door. Did you use semi perm Loctite?
Jim Carter
2016 FR3 30DS
Old 03-19-2017, 01:46 PM   #11
He's talking about the two mushroom type male bolt heads that extend about 1/2 inch from the door, and mate with the female slots in the strike plate on the door jamb when it's closed.
I too have an RV lock that I haven't installed (on my Forester MBS 2401W.) I just checked mine and found that the bolt heads are the same diameter, but a little bit thinner. I doubt if that will be an issue since how much they protrude is adjustable by screwing them in or out.
If RV Lock can't help, McMaster-Carr is an excellent source for just about any bolt you can imagine (and millions of other industrial things too). Also try Fastenall.
Note: I attached 4 photos but this is my first time and I can't tell if their all there or just one. If only one appears, could someone please tell me how to attach several?
bob5560g is offline   Reply With Quote
Old 03-19-2017, 01:53 PM   #12
On my four photos, I made the mistake of clicking on "Video". I now think I figured out how to attach photos. Here comes 4 photos, hope this works!
ID:	132200   Click image for larger version
ID:	132201   Click image for larger version
ID:	132202   Click image for larger version
Old 03-19-2017, 02:22 PM   #13
Good job on the Pics Bob! Youroo!! Blue Loctite is the Removable type!
Old 03-19-2017, 02:36 PM   #14
Thanks for all your ideas. I will try the Loctite method, sounds like the best solution.
Jim Carter
2016 FR3 30DS
Old 03-19-2017, 02:39 PM   #15
Great job on the pics Bob, I too posted pics for the first time. Yours are better than mine...lol
Jim Carter
2016 FR3 30DS
Old 03-19-2017, 03:38 PM   #16
I use the blue stuff for now - monitoring...will go up a level if it shows signs of not holding...it has been a couple of months so far.
Mickey Alberto
2020 F350 4X4 6.7 CCLB, SRW
2020 Heartland Elkridge 38MB
Old 03-19-2017, 04:48 PM   #17
i want to say this is a great post! i will be installing on a 2018 29DS in a few weeks after we take delivery. this would have driven me crazy. i think i will get some red loc-tite. these are bolts that probably should never move again.
Retired USAF
2018 FR3 29DS
Old 03-19-2017, 06:56 PM   #18
There are certain types of Red Loctite that will produce results of Welding! Be careful! Youroo!!
Old 03-19-2017, 07:05 PM   #19
exactly! measure three times, loc-tite once. that bolt aint supposed to move...
Retired USAF
2018 FR3 29DS
Old 03-20-2017, 05:55 AM   #20
DouglasReid's Avatar
Use BLUE locktite! Same material gunsmiths use to keep oru rifle scopes tight on a rifle while in heavy recoil.It will prevent loosening but can still be taken off.
If you use the RED, it will require 300 degrees F to free up. NOT good on your door!
Don't just look at the tube color, look at the color of the Locktite itself when it comes out of the tube. My blue Locktite is in a Red tube and my red Locktite in a blue tube, Go Figure!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
door, lock
