Originally Posted by Combatcoal
i would be careful using red loctite, these bolts may need to be adjusted if the door frame gets out of square/alignment by excess wind while opening, etc. if i'm not mistaken, i read on this forum that these can be one culprit to locking you in or out of the rv (backed out too much caused issues).
darn if you do -- darn if you don't. bad if they work their way out -- bad if they are locked in place and the baseplate gets knarled up. seeing how they are not supposed to move, i will probably go the red-loctite route. measure three times. apply the red stuff once. i will be having to back out my original bolts to make the space work, so they will already be inherently loose. i don't like loose in a bouncy RV. may go with blue -- but probably the red stuff.
best of luck all and be safe!!
b
