Old 05-03-2019, 02:57 PM   #21
KEN9XL's Avatar
Originally Posted by NMWildcat View Post
I've never treated any of my slide seals on any RV with anything. My current RV is 7 years old. Seals are fine. I suspect there are different qualities of seals?
I am going to lean to the side of fully agreeing with what you are saying.
After saying that though, I still feel like the factory employees grab whatever is available to them at the time, especially since everything assembly line piece meal construction. Could I be wrong?
Ken & Marie
2017 Heritage Glen 272RL - 34' 4" hitch to bumper (UVW 7294 lbs / hitch 845 lbs)
2016 GMC Sierra 1500 SLE (4wd w/tow pkg) 5.3 litre V8 engine, payload 1726lbs w/rear axle ratio 3.42, & 9200 lb tow capacity
I wish I started camping earlier in life
KEN9XL is offline   Reply With Quote
Old 07-01-2019, 08:06 PM   #22
I have a 2017 30DS FR3. It is past the standard warranty and I just noticed that both sides of both slides are cracked and near to falling off. I also have some cracking on the inside seals. I have an extended warranty, but still have to pay $200 of the $600 bill. Iíve been told by the service rep, that I should be using a spray on my slide to reduce the friction. Sounds that is only an interesting suggestion. What makes me believe that this wonít repeat in 2 years. Could the problem have been helped along by putting the slide out in cold temperatures?
KRas is offline   Reply With Quote
seal, slide, slide out
