My RV is setup and on shore power. However the radio stopped working and slides wont come in. Seems to be a fuse, any idea where these low voltage fuses are?
The 2 fuses for my 30DS SLIDES are in the breaker box in the bedroom at the floor.
All these fuses are good correct? the fuse labelled slide room would seem to indicate there may be another panel? Did leisurelalrry's suggestion reveal a second panel?
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
The fuse box diagram matches the actual fuses shown in the picture. The slide room fuses, 20 amp and 25 amp shown on the diagram are the the two metal enclosed fuses at the bottom. There is not a second panel.
Did you check the Battery Control Center?
There are fuses inside the SDC-107A located above the house batteries.
