09-04-2018, 09:34 PM
#21
Thanks for posting your resolution and pics. Glad it was a repair you could DIY.
09-05-2018, 04:36 AM
#22
Re-installing the Crown Molding
Access hole for manual slide override in crown backing plywood. I can also reach the motor wiring.
Zoomed out to show the access hole in the crown backing plywood.
Front crown molding trim board attached
Both crown molding trim boards installed. The access hole is now hidden.
I still need to pin nail the bottom trim but it is go enough for another trip or two before winterizing.
09-08-2018, 03:13 PM
#23
Robert,
Since you mentioned that you were in your driveway, I thought I should share our experience...
When we first brought our new FR3 home as newbie RVers, we parked it in our driveway, and put out the slides. When it came time to leave, the bedroom slide came in fine, but the living room slide was unresponsive.
I called Coach-Net, and they pointed me to a circuit breaker in the house-battery compartment that had tripped, and that fixed the problem.
But when Coach-Net heard that we were parked in our driveway, they said that we should never try to operate the slides unless we are completely level.
09-08-2018, 06:31 PM
#24
Originally Posted by Flybob
You said 13.5v at the motor so sounds like you are connected to shore power. Large correct draws usually need some assistance from the battery . if battery is weak or disconnected it will act as you described. Measure the motor voltage with shoe power disconnected.
I'd had both of my 30DS slide gear boxes and motors replaced. Ugh.
Have also noticed... sometimes my slides click if only running on battery power. Plugging the RV into shore power (or running the generator) have allowed the slides to move in/out. Good luck.
FR3 2015 30DS
09-08-2018, 11:44 PM
#25
Originally Posted by vacationlovers
Robert,
I have a concrete driveway that is almost level and I deploy the leveling system before opening the slides. I need the slides out get to the closets in bedroom and the kitchen cabinets. I can not pack for a trip with the slides in.
09-15-2018, 11:50 AM
#26
Originally Posted by rk06382
I did not get a flexible shaft with the FR3. I will be calling on tuesday to find out why.
Lowes has a Dewalt 90 degree flex driver for $35. It maybe easier to get to the motor with the 90 degree flex shaft than with a straight flex. I can make a motor access hole under the first layer of crown moulding.
Just wanted to add Forest River is sending me the missing flex shaft.
09-20-2018, 09:14 PM
#27
slide issue
Before you start changing slide motors or connections, check to make sure it isn't a slide module. Not knowing where yours is, I can't address the ease of checking. I can only say that my slide module went away last yr but as it turns out, on the face of the module, it gives specific instrux on how to bypass the module. Doing so will allow the slide to easily come in, or go out. Seems to me the module was/is made by Lippert(?) Just an idea
09-21-2018, 01:42 AM
#28
The IN & OUT relays were clicking and providing power to the motor wires. The wire was not crimped on the bare copper. Instead it was crimped on the wire insulation.
09-21-2018, 09:40 PM
#29
Good job!
Good news. It was only a poor crimp on one connector to the motor.
rk06382, I am amazed at your ability to find and repair this. I salute you!
09-22-2018, 03:35 PM
#30
I was able to move the slide with the drill. It is real slow but it moved.
I decided to try the switch one more time, just a click. Out of frustration, I tugged on the wiring harness. Now the motor is working........
I have a loose wire somewhere between the motor and the relays.
I was frustrated. I knew it was not the motor or gears, but on the surface the wires looked fine.
As a DIY addict, I was determined to not have to pay someone to fix it. I almost purchased an extended warranty, but decided it was not worth it.
09-26-2018, 01:44 PM
#31
I have a Georgetown XL 369ds and mine also did this. All fuses and breakers were good. Solution was as wife pressed the switch I saw a spark at the connection. Removed the factory connections and relaced with wire nuts and slide works fine. Seems the vibration of travel on the connections will loosen them and poorly krempted from the factory.
Walt & Gerlinda
2017 Georgetown Xl
369 DS :
09-29-2018, 02:16 PM
#32
I think the FR was trying to color code the wires but the yellow connector was to large for the 14 awg motor wire.
06-05-2022, 09:17 AM
#33
slides run when do one is in the rv..cocked jammed slide at 20degrees
Three times my left hand large slide has activated and one motor has started to move the slide out until it jammed and tore up the inside trim and bent the front wall on the outside.
the first time was when it was in the shop and it opened the st hlide into a post and broke a window. the shop thought someone had move the slide so they ordered a new window (in 2020 took 6 months) while the window was being ordered the rv was parked and the slide opened and tore up the trim and damage the outside metal. The shop was calling it the "ghost" RV . they readjusted the stops and fixed the damages thinking it must have been someone getting in the
RV even though the keys were locked up in the office. After "fixing" it the second time they were glad for me to come get it....Now at my house one motor has decided to move again and cocked the slide ...trim inside knocked off in the back and the front outside metal in now bent.......
by the way the slide in and out buttons had stopped working and you could not go through the reset procedure to reset the in and out stop locations.
Anybody experience this .....Last time I talked to Forest River/Dynamax about this I don't believe they either cared or believed me...but after three time I think something needs to be done.
rv
10-25-2022, 11:37 AM
#34
Manual slide
If you disconnect & remove the slide motor, is it possible to manually push the slide in & out?
10-25-2022, 11:49 AM
#35
You do realize that this thread is over 4 years old?
2016 Salem 27RKSS
10-25-2022, 11:59 AM
#36
Yes
10-25-2022, 12:03 PM
#37
The last unanswered question was posted 5 months ago.
10-25-2022, 01:10 PM
#38
Are you asking about a slide system exactly like the one this thread was started about many years ago?
Not all slide systems are the same so unless you are piggybacking onto this thread and have the exact same slide system, we could possibly give you irrelevant information.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
10-25-2022, 01:12 PM
#39
It would help other FR3 owners if you posted what year, make and model number of FR3 you're asking about. Or put that information in your profile or signature.
Sent from my SM-G781U using Forest River Forums mobile app
10-25-2022, 01:17 PM
#40
No.
There is eight cables on the slide, Four IN & four OUT. The slide motor shaft is part of the gear box.
The manual override is to use a flexible shaft inserted into the end of the slide motor to move slide in or out.
see videos below:
