Old 05-31-2023, 06:01 PM   #1
Water Quick Connect
FR3 32 DS want to put a quick connect on city water outlet. What size fitting do I use with standard white water hose for drinking water
Misket is offline   Reply With Quote
Old 06-01-2023, 12:41 PM   #2
ForestGump34DS's Avatar
Nothing special here....just standard hose quick connects. I also used 90 degree connectors to avoid hose kinks...
https://www.amazon.com/Twinkle-Star-...id_rp_0_1_ec_i
https://www.amazon.com/Twinkle-Star-...s%2C256&sr=8-8
2022 FR3 34DS
ForestGump34DS is offline   Reply With Quote
Old 06-01-2023, 12:49 PM   #3
And order/buy enough of the same size. There are at least two different sizes of the quick disconnects.
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab
Max Tow Package
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 06-02-2023, 05:46 AM   #4
A standard garden hose thread is designated as "3/4 GHT". Select a disconnect with a large center bore so the water flow does not get choked down too much. And buy a number of the same kind when you get them as it's hard to find disconnects from different manufacturers that will work together.
esdill is offline   Reply With Quote
Old 06-05-2023, 07:56 AM   #5
I'm with ESDILL on this. I will add that, IMHO, inexpensive fitting are a source of frustration, constant leaks. Buy quality fittings from Garret Wade or A. M. Leonard, more expensive but well worth it. The A M Leonard are very wide bore for maximum water flow and you can buy packages of the O-rings at the same time for maintenance replacement.
colmbarry is offline   Reply With Quote
Old 06-13-2023, 10:27 AM   #6
RVwino's Avatar
X2
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
RVwino is offline   Reply With Quote
Old 06-13-2023, 02:31 PM   #7
robo44's Avatar
X2
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47
robo44 is offline   Reply With Quote
water
