09-08-2021, 02:32 PM
Where to buy body triming parts
I'm trying to buy trim parts from forest river company.
But I read on this form somewhere that there should be a build sheet that will list all components on a motorhome. I am trying to find out what trim pieces are on a 2018 fr3 30ds.
Specifically I need the bottom extruded aluminum piece skirt and the rear corner bead that holds the back and the side panels. The corner bead is the piece that has that vinyl trim to hide the screws approximately 104 in Long and I can't find anything on the internet that long. The skirt is the one that's rounded kind of has a flat on it it's at the very bottom of the side panels. Again I can't find anything with the rounded and that little flat so I may have to buy that from Forest River.
I bought this unit used and I don't have any build sheet from what they gave me. If anyone has a build sheet and can maybe look up those pieces I will try to secure those online Save Me probably some money.
Any help would be really appreciated, thanks.
09-08-2021, 04:55 PM
Not that I heard of or for at least 2018 and newer FR3, It might exist, but I've always had to call FR Customer Service with your VIN and then they will order a part but probably have to go through a dealer
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
09-08-2021, 05:07 PM
You may or may not be able to get trim parts for a 2018 from Forest River. Another possible source is a RV salvage yard.
Pictures of what you are looking for may help.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
09-09-2021, 07:13 AM
Robo44 is correct. Call (or email) FR with your Vin and they will provide you with a part #, then you'll have to go to a dealer, to have them order for you. I just went thru this procedure to get a fender skirt for my 2014 FR3. You'll also have to pay for the shipping.
2014 FR3 30DS
2005 Dodge Dakota 4WD
09-09-2021, 07:37 AM
Look on amazon under RV Trim molding. I bought the vinyl insert as well as the aluminum that holds the trim from them. Not sure if you can get 104 inch long piece. at least you can find the manufacturer and maybe contact them for the longer piece.
09-09-2021, 01:47 PM
Length is the problem
Length is the problem. It's really hard to get people to ship stuff longer than about 6 feet (72 in.) I was looking at rain gutter molding--the kind that accepts the vinyl insert, has a rain gutter, and also has the channel to insert the top edge of the awning.
If you look at our 38' trailer, you could tell from where the joints are that the factory gets it in about 20' lengths. But when I tried to find it, the only source I could find was 8' lengths on eBay and even the shipping on those was expensive.
Shipping a long (although slim and lightweight) item like this means a trucker to your door and that ain't cheap. Plus you have to be home to sign for it.
If you're lucky, you might be able to find the manufacturer or a distributor near to you that would let you pick one up. Or you might be able to find a piece at an RV salvage yard near you.
Larry
09-09-2021, 01:51 PM
Try searching "RV trim Rub rail" RV edge Trim", "RV Edge molding"
Doing the search, I found eBay, Amazon, eTrailer, and other sites. You can start with the below. I noted lengths over 92"
https://www.bing.com/search?q=rv+alu...FORM=QBRE&sp=1
09-09-2021, 04:12 PM
Thanks for all your help.
These are what I needed.
The bottom j channel is $465 a foot and the corner molding is $399 a foot.
The j channel I need is 4' 3", so I need 5 feet. The corner is just shy of 9'.
This will cost $6300 and I still have to paint it and cut to fit.
I did find 8' corner pieces for like $20 on ebay. But the j channel I can't find the exact match. I could probably retrim the whole outside in a different channel for cheaper.
I just don't understand how they got those prices.
I bent the 2 up a bit so I may just try to fix them myself.
09-09-2021, 05:38 PM
I have a contact for you, you can get parts through them and they get them front FR so they are exact match parts, they will just need your VIN. if you can’t find what you need on their online store there’s a link for they’re email. Tell them what you want. It takes a few days to week for a response sometimes but worth it. I just ordered some J-wrap for my 2015 Heritage Glenn and they got it perfectly matched. And it was $12.00/foot. The killer was the shipping but still way cheaper than what you’re looking at.. below is a link.
https://elkrv.com/
Good luck and message me if you need anything more.
09-09-2021, 07:41 PM
These don't appear to be badly damaged. You can use blocks of wood and a hammer on a solid flat surface and to form them. Aluminum is soft and pretty easy to work with.
09-10-2021, 07:31 AM
Dburr, I ordered an 8 ft. piece of shower trim for my 2014 not too long ago (thru the dealer) from forest river and they shipped the 8 ft. to the dealer. Hope that helps
2014 FR3 30DS
09-10-2021, 08:02 AM
That's a picture before the mishap.
On a better note: I contacted FR again with the quote and they think they didn't use a decimal point. $4.65, $3.99 they should be. So now I'm at $63, much better.
dsjohns71:
I will try that contact, thanks!
11-02-2021, 11:18 AM
dsjohns71:
lmao
