Old 10-28-2021, 03:35 PM   #1
ForestGump34DS's Avatar
Where's Antenna Amplifier Switch ???
Can't find Wineguard TV antenna amp switch on 2022 FR3 34DS....any help would be appreciated !!!
ForestGump34DS is offline   Reply With Quote
Old 10-28-2021, 03:44 PM   #2
Right on the wall plate. That's where mine is. Let me know how your tv reception is after you find it and scan for channels. Mine is horrible. I need to figure that thing out.
Badger_71 is offline   Reply With Quote
Old 10-28-2021, 03:46 PM   #3
jeff64's Avatar
Follow antenna lead from TV set to wall plate. Button is small!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 10-28-2021, 04:13 PM   #4
You guys make it sound easy....if it was easy I would have found it by now...
Here's a pic of my connetions & wallplate behind swing out TV. Antenna goes into the top of large box below ac power plugs....Still don't see the antenna power button ???
Old 10-28-2021, 04:24 PM   #5
Is that the back side of the plate? Mine is just a cable TV outlet with a small push button on the front.
Old 10-28-2021, 04:24 PM   #6
jeff64's Avatar
Does that blue rectangle appear to be a power button and maybe light up if you push it? Is that the antenna plugging into it? Are there any type of power buttons on the directional control knob for the antenna in your ceiling. If you find it make sure to rotate antenna towards
broadcasting station . That's all I got!
14K Equalizer
Old 10-28-2021, 04:34 PM   #7
Thanks for trying guys....I don't have a wall plate like badger's, and I have a Wineguard 360 plus that doesn't rotate...!!! I'll keep waiting for another "answer"??? The "blue on my plate is a UBS connector....
Old 10-28-2021, 04:34 PM   #8
In my camper the booster switch is on the plate in the bedroom. The living room plate does not have a button and the tv will not receive any channels until the button in the bedroom is on.
CGJT is offline   Reply With Quote
Old 10-29-2021, 07:06 AM   #9
In my 33DS, the switch is in the cabinet directly above the kitchen sink.
2021 Forest River FR3 33DS
2019 Jeep Cherokee Trailhawk
besweeet is offline   Reply With Quote
Old 10-29-2021, 09:37 AM   #10
BINGO !!! Thanks so much....I found it in the same place !!! I never go near the kitchen sink except to put dirty dishes in it !!!
antenna, switch
