Old 06-10-2024, 02:50 PM   #1
rk06382's Avatar
Windshield wiper pivot post
The Windshield wiper pivot post on the passenger side is locked up. Bad bearing?
I removed the long arm between the two & the driver side post is fine. Does anyone know how get to the bearings?
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 06-10-2024, 02:57 PM   #2
Oaklevel's Avatar
May have to replace the post assembly. Many older cars are a sealed assembly. Never taken a new one apart. So I am guessing here.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 06-10-2024, 06:06 PM   #3
Welcome to Forest River Forums!
DogMan635 is offline   Reply With Quote
Old 06-11-2024, 03:21 PM   #4
rk06382's Avatar
Got a quote from AM Equipment for $709.15 for the Wiper motor assembly. (plus shipping)
Robert
Old 06-11-2024, 03:42 PM   #5
removing the center arm leaves one connected to wiper motor
if you can find the arm at the motor and disconnect you can tell if it is a frozen wiper bearing/bushing/arm or the motor
I would not hesitate to use some of your favorite spray lubricant where you thing the bearing would be in the post
wiggle it without motor connected to work it in place
NO idea how yours is assembled but every wiper motor and arm combo I have ever seen kinda works that way?
so this is an educated guess without seeing one of yours
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is online now   Reply With Quote
Old 06-11-2024, 05:31 PM   #6
Contact FR3 Parts Admin?
Why not contact the FR3 Parts Administrator and ask who they buy the wiper assembly from? Then contact them and get just the post. Looks like it's Greg Wagner or Kathy Wing. Click the image twice to enlarge it.
Larry
Larry-NC is offline   Reply With Quote
Old 06-11-2024, 07:19 PM   #7
rk06382's Avatar
This is a photo of my FR3:
AM Equipment makes the wiper assembly part #238-2060. It is not the same as below. The one in my FR3 has a curved pipe between the posts. They are built to NHSA (National Highway Safety Administration) standards.
Robert
Old 06-13-2024, 08:52 AM   #8
Disassembly
Typically, you first remove the wiper arm. On your model, it's held on by the force of the spring that holds the arm against the windshield. You would lift with one hand around the wiper arm and a finger of the other hand on the opposite side. Pull with most force on the finger, so forces on the cap are equal on both sides, and the wiper arm should pop right off. (All the cars in the '50s, '60s, and '70s work this way. Some still do.)
Beneath the arm you should see a hex nut. There might be a decorative cover or weather seal above it. Turn the nut to the left, and the shaft assembly should drop out.
If necessary, you could do this on both sides and remove what is called the entire "wiper transmission."
CAUTION: Avoid removing the arm that attaches to the wiper motor itself. It is positioned so the wipers park at the extreme end of travel. It is very difficult to get that arm positioned exactly the same way, so the wipers park at the extreme position. Ask me how I know.
Larry
