Old 04-05-2023, 03:03 PM   #1
thomlinson's Avatar
Need replacement bolt for main door lock
I have the standard main door look - deadbolt and passage lock, keyed, in black. One of the four shoulder screws that holds it in place has fallen out and been lost. The thread is 8-32, and it is 3/4" long, with a #2 square drive head. I have replaced it temporarily with an 8-32 x 3/4" machine screw, but I suspect the shoulder part of the bolt is there for a purpose - stability perhaps. Does anyone have any idea where I can find a replacement screw? I've tried rvlocksandmore.com, which is referenced in a sticker on the lock, but that site is not a lot of help. I checked Lowes, Grainger, and Amazon without luck.
John Thomlinson
San Pedro, CA
2016 EVO-ATS 200RDS
Slowly figuring out the meaning of life
thomlinson is offline   Reply With Quote
Old 04-05-2023, 03:31 PM   #2
Poke around on Amazon… here is a start…
https://www.amazon.com/s?k=Screws&rh...es_sbs_fst_scr
2016 Siverback 33IK, Towed 60K+ mile
dalford is online now   Reply With Quote
Old 04-05-2023, 03:45 PM   #3
thomlinson's Avatar
I had tried that, but to no avail - the combination I want does not exist, apparently. Thanks.
John Thomlinson
San Pedro, CA
2016 EVO-ATS 200RDS
Old 04-05-2023, 03:55 PM   #4
I think you are overthinking it..lol… keep an eye on your fix.. I’m sure it will hold up…
Old 04-05-2023, 04:59 PM   #5
Do you have a Fastenal near you?
The other suggestion would be the lock manufacturer if you know it.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 04-05-2023, 06:13 PM   #6
thomlinson's Avatar
If something's worth thinking about, it's worth overthinking.
That certainly is my default position - keep an eye on it for a while, then completely forget about it.
Cheers
John Thomlinson
San Pedro, CA
2016 EVO-ATS 200RDS
Old 04-05-2023, 06:19 PM   #7
thomlinson's Avatar
I'll check out Fastenal, though I don't see what I need on their website. There's nothing on the lock to indicate manufacturer, that I can see, just the sticker referring any questions to rvlocksandmore.
John Thomlinson
San Pedro, CA
2016 EVO-ATS 200RDS
Old 04-05-2023, 06:29 PM   #8
Maybe this company?
https://www.wescofastec.com/
I would try a local hardware store like Ace. Ours carries quite a few odd hardware pieces in the same section as the screws, nuts and bolts.
Here are some pictures and dimensions.
https://www.mcmaster.com/countersunk...oulder-screws/
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab 4x4
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 04-05-2023, 06:37 PM   #9
thomlinson's Avatar
Thanks - a promising couple of leads to follow up. I have occasionally found odd specialty items at Ace or True Value - next time I'm near one and I'll check it out.
John Thomlinson
San Pedro, CA
2016 EVO-ATS 200RDS
door, lock, replacement
