Travel Trailer leans to passenger side
I have a Forest River Work and Play toy hauler. I had to have the springs replaced once on the road on our third trip out--the original springs were installed with no bushings. After a couple more trips, I noticed a lean like yours. Upon close inspection, my springs had flattened out, looked like yours. The springs should have an even arc upward from the axle. The replaced springs that were installed had the correct rating but were made in China. I replaced all four springs with Dexter springs and no problem since then. I upgraded my shackles with heavier shackles and shackle bolts that can be lubed. Too bad the manufacturers don't use good materials to begin with, good luck with resolving your issue.
