Old 09-03-2019, 09:22 AM   #1
SPCF's Avatar
AC noise level too high
Anyone have any good ideas on how to reduce the noise level on the ACs in the Legacy?
It is so loud that it becomes hard to even talk in the couch if it is running even at low speed.
I read some article about doing so but the mod did not work so good.
Sergio & Patricia
Legacy C38. 2018.
South Texas.
SPCF is offline   Reply With Quote
Old 09-03-2019, 09:58 AM   #2
I'll agree that RV air conditioners are something you may have to adjust to, but the reality is that we demand cold air, and therefore we have to deal with the sounds that come with it - if you think about it, the unit is right above your head, and the main return/outlet is also right above your head, and especially if you have two or three units on the roof...there's little way to get 'away' from them.
Some have installed further insulation in the main outlets, with some success, but I'm not sure that there will ever be a way to make these units 'quiet', at least not much more than they already 'are'...
When we are in the living room area, whether watching tv, or eating a meal, we actually only use the REAR air conditioner, shutting off it's main outlet, OPENING the living area Main Outlet, and shutting off many of the ceiling outlets near the rear of the coach in order to put more of the air out into the living area...making for a rather nice and quieter time. We also use floor fans to move the air, which is a large part of keeping any space cool.
When we are in the bedroom at bedtime, watching tv, we do the opposite ... we've grown accustomed to understand that simply turning 'on' the air condtioner(s) is not the only part of the equation.
And, YES, it is HOT!!!! almost everywhere right now - we had a day last week where the high was in the low 80s, and we 'thought' that the weather had turned and we were moving into more of a temperate time....oh no!!! This week has Wednesday at 94!!
The Turners...
formerFR is offline   Reply With Quote
Old 09-03-2019, 12:41 PM   #3
SPCF's Avatar
That is basically what we have been doing but in Texas with the temp in the low 100's only one unit wont cut it.
I wonder if there is a way to put a mini-split and duct the cold air into the furnace ducts from the cargo bay. and hang the outside unit in the back of the bus.
Sergio & Patricia
Legacy C38. 2018.
South Texas.
Old 09-05-2019, 08:09 AM   #4
dan-nickie's Avatar
https://wackoproducts.com/
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 09-05-2019, 08:20 AM   #5
Originally Posted by dan-nickie View Post
X2!
We LOVE our country!
pkmkaz is offline   Reply With Quote
Old 09-05-2019, 08:32 AM   #6
MillMitch's Avatar
does the wackoproduct work? i watched the install video, and they block the air dump and then put a cover over the AC that reroutes the air across the blocked air dump and into the intake. Interesting theory.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 09-05-2019, 08:33 AM   #7
psw757's Avatar
How much does this reduce the noise level and do you think it increases the efficiency/flow through the central ducting?
Wish they had a average DB reduction on their site.
psw757 is offline   Reply With Quote
Old 09-05-2019, 08:42 AM   #8
It works, you no longer have the air dump and all of the air goes through the ductwork you have. Much quieter!
Old 09-05-2019, 08:47 AM   #9
They do have some DB comparisons on their Facebook page from a customer.
It is NOT a video, just photos so take it for what that's worth.
I did see it demonstrated at a show and their was some noise level reduction but in the case of those with non ducted INTAKE using a Coleman Mach unit, you lose the quick dump feature.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 09-05-2019, 08:52 AM   #10
Iwannacamp's Avatar
The only issues I have with this are... price and elimination of dump feature.
I have said this I think... In residential a/c insulating the return air gets rid of a LOT of noise.
Honestly I can deal with noise to be cool...
2017 Puma 297RLSS
Old 09-05-2019, 09:13 AM   #11
SPCF's Avatar
Thanks, I saw the install video and I am really debating if the amount of noise reduction is worth the expense ($189.00), to top it off we will loose the option to open the cold vent to cool the area a bit faster. DW uses that a lot in the very hot days when both ACs are going at full tilt...
Sergio & Patricia
Legacy C38. 2018.
South Texas.
Old 09-05-2019, 09:14 AM   #12
Jim34RL's Avatar
This is one of the reason we purchased our Cedar Creek model, there is no air dump from either A/C. Just ducted A/C lines in the celling through out the trailer. We can talk and listen to a TV when the A/C is operating. There is some noise but not objectional like a A/C that dumps into the room. When we sleep at night I shut off the front A/C and just run the rear A/C on a continuous low speed fan. Very quiet we do not even hear our A/C operating at night in the front bedroom.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 09-05-2019, 11:27 AM   #13
psw757's Avatar
Noisy Ac thread?
Where did the thread go discussing that product to replace the ac grill?
Old 09-05-2019, 12:19 PM   #14
bob213's Avatar
Don't know but I'm very tempted. Just can't seem to get my wallet out of my pocket
https://www.rvupgradestore.com/WackO...it-p/da100.htm
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
bob213 is offline   Reply With Quote
Old 09-05-2019, 12:22 PM   #15
MillMitch's Avatar
Looks like it disappeared. I just searched everything i posted and that one is missing. Go figure.
Mitch in MN
Old 09-05-2019, 12:37 PM   #16
psw757's Avatar
Took some DB readings in our legacy at both the front and bedroom areas, ducted reading and air dump reading.
Seated On the sofa ac directly overhead where we would watch tv
Db with fan on low was 64/65 dB
Med fan was 66
Hi fan was 68/69
Air dump open was 71-73 dB
Bedroom readings were taken laying on bed and all values were the same.
If this gizmo does what it says and reduces 5-10db and doesn’t reduce flow, that is pretty amazing and will likely be ordering 2.
Old 09-05-2019, 06:05 PM   #17
SPCF's Avatar
Indeed, nowhere to be found.... ADMIN?? what happened to my posts?
Sergio & Patricia
Legacy C38. 2018.
South Texas.
Old 09-05-2019, 06:10 PM   #18
wmtire's Avatar
It had some links in it that needed to be researched as some set our spam filters bells off. It's about to be put back in play. No worries.
We have anti-spam stuff that this happens to sometimes when members put links in their posts. It then requires us to manually check the link and also to make sure it's not a spammer trying to mine the membership here. When the links set the alarms off (which multiple instances of the same link can do), then the site team has to determine if either of these guidelines is being run afoul of. It does sometimes take a bit to determine and the thread/posts/links may not be visible during the process.
  • Our user base is not a resource to be "mined" by individuals, groups, or businesses, for profit or not for profit. The use of Forest River Forums to solicit members and/or customers for other groups, lists or businesses is expressly forbidden.
  • Participants may not post affiliate links or links to direct others to any pages at their own commercial website or website in which they have a commercial interest, including informational pages unless a vendor account has been established.
2011 Flagstaff 831 RLBSS
Old 09-05-2019, 06:17 PM   #19
SPCF's Avatar
This tread was mia... now it is back.. or is it?
Sergio & Patricia
Legacy C38. 2018.
South Texas.
Old 09-05-2019, 06:30 PM   #20
Mr. Dan's Avatar
Can you see it?
noise
