Originally Posted by Favfour
Under the dash you can swap one of the side camera and the rear camera connectors to see if the problem switches or stays the same. Switches, it’s the rear camera. stays the same the camera is good and something wrong with the wire or connection in the box.
Happened to me I had to replace the camera. Easy fix, if you remove the camera there should be a sticker of the manufacture. Forget the company but very helpful and easy to work with.
Thank you for the GREAT advice ! I removed the switch control panel and found the 3 camera wires ( along with enough unused wires to wire the space shuttle ) and unscrewed each cable and moved them around and voila, the rear camera started working. Thanks again !!
