Just had a Sealtech pressure tested last week, and no leaks. BUT 3 days later found water dripping into the bathroom from the fan. It was raining a lot.
Found that the original Dicor seal around the fan housing detached from the plastic shroud. It did not show leak on the pressure test, I actually had to press on it a little to see it was not bonded to the plastic as it should.
It was very well bonded to the roof and bonded ok on other sessions of the shroud.
I cleaned and re-apply Dicor to that session for now (45 deg outside) and will wait till a bit warmer to rip it all out and fix it. So far no leaks...
One may want to physically check it out next time on the roof.
Happy travels.
