Old 09-15-2020, 08:48 AM   #1
srappleby's Avatar
Shurflo water pump
My SHURflo freshwater pump, 4048-153-E75, runs for about 3 min when I switch it on after disconnecting from city water. After that, it works great. No leaks inside or on the ground and it doesnít cycle on by itself indicating a leak in pressure in the system. Is this a pressure switch failing or maybe something else?
Steve
2014 Legacy SR300 340BH
2010 CR-V Toad
srappleby is offline   Reply With Quote
Old 09-15-2020, 09:03 AM   #2
SeaDog's Avatar
reading your post I don't see what the problem is its sounds like it is working as it should. You may want to explain what the problem is.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-15-2020, 09:17 AM   #3
srappleby's Avatar
Well, only problem is this is a new development. Up until now, when I switched on the pump, it ran for only a couple of seconds. While the pump is currently doing the job itís supposed too, if the pressure switch is failing, Iíd prefer to replace the $16 part at my convenience rather than having a complete failure while traveling.
2010 CR-V Toad
Old 09-15-2020, 09:21 AM   #4
I have had longer than expected runtime (first time) when there is air in the lines.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 09-15-2020, 07:09 PM   #5
Favfour's Avatar
Shurflo water pump
I noticed a similar issue recently on my 2018 340BH. Turned out to be my ice maker was on. When I turned on the pump it ran for a while to fill up the tray. Does it happen as soon as you disconnect from city water? If so that probably isnít your issue.
Favfour is offline   Reply With Quote
Old 09-15-2020, 08:04 PM   #6
SeaDog's Avatar
I doubt the amount of time running is the pressure switch and more then likely the pump getting tired (wearing out) If it were the pressure switch running longer would mean developing more pressure not less. how is the flow from the pump? the pressure switch is internal to the pump
Retired Navy
Old 09-16-2020, 04:43 AM   #7
srappleby's Avatar
No air in the lines as it happens when Iím switching over from city water to tank when disconnecting from a campsite.
2010 CR-V Toad
Old 09-16-2020, 04:44 AM   #8
srappleby's Avatar
The pressure switch is external.
2010 CR-V Toad
Old 09-16-2020, 04:53 AM   #9
srappleby's Avatar
Yes, happens when I am ready to break camp. I turn on the water pump and shut off the city water. For the first three years, the pump would run for three, maybe five seconds. All of a sudden, itís three minutes or more. This is the only time it does this. While running off tank water, it works normal and shuts off almost immediately after turning off the faucet. Nothing has changed with the coach plumbing.
Iím thinking that the pressure switch may be sticking and not shutting down the pump at 55 psi. Think Iíll call the manufacturer and see what they suggest. Is Shurflo owned by Lippert Components yet? Lol
2010 CR-V Toad
Old 10-17-2020, 01:54 PM   #10
captnrick3's Avatar
Sounds to me like the internal by pass in the pump (which is supposed to make it cycle less) has gotten weak or out of adjustment somehow. Ours has done that from time to time and then gets over it. I'm considering just changing the pump before we get caught in a bad place since we dry camp from time to time.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 10-17-2020, 06:30 PM   #11
5er_tom's Avatar
I had to replace my water pump yesterday. It ran, made all the normal sounds, but did not pump water. Of course they never put the water pump in a easy to reach location. This 75 year old body did not like climbing up into the storage bay for the replacement, but it had to be done. I donít remember why, but I had a new one in the box. Not something one normally carries along, but glad I had it.
Tom & Renťe
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is offline   Reply With Quote
Old 10-25-2020, 04:51 AM   #12
srappleby's Avatar
Thanks Rick. Think Iíll change mine when I have a chance.
2010 CR-V Toad
pump, water, water pump
