Slide Controller replacement
During one of my first trips out, I was camping in an isolated area and couldn't get one of the slides to go out. After tinkering around I noticed the slide controller, for the slide that wasn't moving, was wet from a leak. I attached the other slide controller and the slide worked. When I got home I took my coach into the dealer and they claimed to fix the leak and the slide controller. I have had the slides in and out several times since then without any problem. The other day, however, the same slide once again failed. This time it was trying to work but not moving both ends. The back end was moving a bit but the front end didn't budge. After trying a few things, I decided to swap out the slide controllers and once again this worked. Has anyone else had this experience? I feel like it would be a good idea to keep an extra controller on hand. Any suggestions on where I should buy another controller?
Thanks!
