A 24” TV would be tight in the factory PAWS mount (assuming you have one, mine was missing the internal one ;( mostly due to the front ceiling curvature.
You also have to worry about TV weight vs. that plastic slide mount. I use a steel articulated arm with two large carriage screws into a stud. 22” was given to me, replaced the 20” I was using, tiny increase. Here’s a pic I took to show the front panel access, but shows the 22” TV taking up most of the above window space.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 200W CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
