If this has not happened before, I would check the output of your converter. After a while, when the batteries are fully charged, it should drop down to 13.6 or even 13.3 volts to maintain the batteries and supply other loads in the coach. If the fan is running it may be stuck on high voltage, which is bad, or you may have a big load somewhere that is taxing it.
2015 335DS
