Old 04-29-2016, 10:08 AM   #1
26dbh gutter issue
Any ideas of what to do about leaking gutters where they attempted to connect 2 pieces so the gutter runs the length of the TT? They have a glob of sealant sitting in there that obviously doesn't work on both sides.
Tngahan is offline   Reply With Quote
Old 04-29-2016, 10:14 AM   #2
JustB_Rad's Avatar
butyl tape the sections together? I think I have the same problem on my awning side....my LED's went out at that spot and i've had water dripping down there too.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 04-29-2016, 10:15 AM   #3
It's happening on both sides of the camper with the back side running directly onto the slide out, which scares me.
Old 04-29-2016, 10:24 AM   #4
JustB_Rad's Avatar
Maybe a thin piece of EPDM flashing glued to the inside of the gutter a couple inches each way of the joint would work too. It's thin and meant to keep water out
Old 04-29-2016, 01:47 PM   #5
Thanks for the post. I noticed mine was leaking a little on the curb side. Guess I'd better look into it...
Family of six, camping in a Grey Wolf 26DBH LTD pushing a 2010 Armada via 10k/1k HaulMaster WDH stopped by a Prodigy P2 brake controller
Tug: 2010 2wd Nissan Armada Titanium with tow package.
Specs: Max Trailer Weight 9,100, Tongue Load: 910, GCWR: 15,100, GVWR: 7,150, Payload: 1,592
DadOfTwo is offline   Reply With Quote
Old 04-29-2016, 01:50 PM   #6
I called my dealership, which is 2.5 hrs away, and they said all they do is pull off the sealant and do it again...said I can do that. He said that's probably the biggest reason for calls with new campers because the manufacturer just globs it on without checking if it's actually sealed.
Old 04-29-2016, 02:20 PM   #7
Who Dares, Wins
doc73's Avatar
All I did was seal mine and do a better job of making sure it was actually sealed.
2015 Chevy HD D-Max
2022 Impression 315MB
Old 05-01-2016, 07:44 PM   #8
What kind of sealant did you use? Mine is doing the same thing.
bmarleyzq8 is offline   Reply With Quote
Old 05-01-2016, 07:45 PM   #9
Who Dares, Wins
doc73's Avatar
If that was to me, just the geocel I used to seal the seams with.
2015 Chevy HD D-Max
Old 05-01-2016, 07:58 PM   #10
Common issue. I have it on mine. Have not fixed yet. Going to see if I dig it off and try flex seal.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
