So I found the water heater and have installed the winterizing kit at the water pump. Turned the pump on, and was able to get antifreeze to come out of the bathroom sink and toilet. Went to the kitchen and there was a lot of sputtering, but not much antifreeze coming out. Went back and crawled under the bed and the pump was no longer drawing antifreeze out of the jug
I may not have my water heater bypass valves set correctly? I've searched online and can't find any info on this particular bypass setup. How should the valves be positioned for winterizing?
Closeup of the bottom valve, which I'm pretty sure is correct?
Thanks in advance for any assistance, I'm frustrated enough that I almost want to just quit trying..
Vel
