I would think 'prep' would be all the things the factory normally does for a 2nd a/c unit, but just 'without' the 2nd a/c unit itself - 120v wiring from the breaker to the unit, 12v wiring from the thermostat to the unit, and even yes, having it attach to the existing duct work, which is how most 'ducted' multi-unit designs work.
If there is an existing duct outlet where this 'prep' area is, I would imagine that you'd find the 120v and 12v wire terminations there, ready to attach to the new a/c unit, when installed.
The wire from the roof area for the 120v power may be unattached behind your Main Electric Panel, and the same for the 12v wire to the Thermostat, or the place 'for' the Thermostat, which may be just under the current one. When the hole is cut into the appropriate roof area, the existing duct should be right below it, ready to cut the proper size hole and set the a/c unit down into. The ceiling of the area where this 'prep' is will also be where your 'cover' is attached to the unit, to pretty everything up.
The Turners...
