Originally Posted by ChrisMoore
So I have a factory black tank flush, is there any benefit to adding this one? The only issue is the flush is on the opposite side as my dump making it difficult to flush, but I never worried about it, I only flush every couple trips.
Fine with what you have.
I use my flush every couple of months and am full time. I just probably only have it on for a minute or so total and open and close the gate valve every ten seconds four or five times. Have never seen a build up yet in my tank looking through the toilet.
Usually flush when a dump site has a long enough hose and it has been a while since I did it. I have a hose specifically for it but it pretty much stays put.
Leaving a bit of water in your tank between trips will keep anything from solidifying. At least that is my thoughts.
