Old 11-03-2020, 11:22 AM   #1
Long time camper.
ANOTHER Winterizing mystery
Ok, Iíve been around a while. For the first time I used RV antifreeze on my 2015 Cherokee. Used to run in the air pressure group, but, you guys convinced me to go with the antifreeze.
So, I learned earlier this year from youse, there is a little button under the screen in the city water port. If the pump doesnít pump, try pushing that button. You didnít tell me a quart of water will rush out all over my shirt.
Now I completed the antifreeze pumping, sucking, spilling and dumping. On my last walk around, I thought check that button. Yes, again a quart of water (not antifreeze) on my shirt.
What damage would be caused by not releasing that water? Never saw recommendations to let that water out for freezing temps. Why did my water pump, pump water all summer with pressure in the city water line? What does that little shirt squirter do, besides squirting shirts?
Thanks, SamTummo
samTummo is offline   Reply With Quote
Old 11-03-2020, 11:36 AM   #2
That little 'squirter' is a check valve so that when you are NOT connected to city water, the on-board pump does not push water out the city water connection. Pushing that check valve has been in most all the recommendations I've seen for winterizing with antifreeze so I'm not sure why you missed it.
Below is a simple schematic of the plumbing system. You can see how the city water side and the on-board water side connect.
BTW... the often discussed failure of the internal check valve inside the on-board water pump does exactly the same thing when on city water... it keeps the city water from backflowing into the fresh tank. (hopefully!)
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 11-03-2020, 12:03 PM   #3
Brake is on left
The Evil Twin's Avatar
If you leave a faucet on after turning off the water pump, it will relieve the pressure in the system and your shirt squirter won't squirt.
The Evil Twin is offline   Reply With Quote
Old 11-03-2020, 01:50 PM   #4
D W
D W's Avatar
The whole object of pushing the button is to ensure the antifreeze pushes the water out of that section of the line. The OP stated he had just water squirting out, therefor that section of the line was not winterized. I always start with the outside shower and city water connection then work my way from the bathroom to the kitchen where the water pump is located. The same way you bleed brakes on an automobile. Lastly I crack the low point drains and let gravity do it's job. When I get pink stuff at all fixtures, I'm done.
In full disclosure, the first time I winterized I also got a sleeve full of water, then antifreeze. The next time I new enough to stand off to the side when I pushed the button.
2016 Salem 27RKSS
D W is offline   Reply With Quote
winter, winterizing
