You should have a low point drain under the fresh water tank.
Then you should have another set of red and blue pipes under there. Usually they are near the edge of the trailer so that you can reach them easily (but not always)
Those drain the hot and cold water from the faucets and piping and should be capped or have a valve on them.
2015 Dynamax REV 24TB class C
