08-11-2017, 01:55 PM
#21
I saw a video on YouTube one time showing how to adjust the latch on the hitch to fit more or less tight against the ball. Not sure if something like that applies in your case or not.
I have trouble sometimes if my truck has a tilt side to side but the trailer doesn't.
2016 Wildwood 230BH X-Lite
2011 Ford XLT Supercab
Days Camping -
'15 (6) : '16 (32) : '17 (41) : '18 (35) : '19 (38) : '20 (15) : '21 (15) :
08-11-2017, 02:12 PM
#22
Tom
I had that issue and it was a PITA, if your ball is tilted downward a good bit it will put it in a bind. I would have to chock the TT wheels, tap forward with TV and put in neutral. Also it is pretty obvious to me if the ball was 2" and the coupler was 2-5/16 this wouldn't be an issue, haha. I have since moved on to a Propride, no longer have this issue.
08-11-2017, 02:30 PM
#23
did you try changing the ball
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
08-11-2017, 02:34 PM
#24
My thoughts exactly......shhhh, this will be our own little secret. Don't want to spoil the fun.
Rick & Brian
2023 Flagstaff 206STSE
2019 Flagstaff HW29SC ( sold )
2017 Salem Cruise Lite 232RBXL ( sold )
2014 Ford 150 XLT 5.0 2wd
08-11-2017, 03:13 PM
#25
Originally Posted by Scrapper
That should be 2-5/16". Surprised you didn't loose the trailer along the way. Or at least feel it jerking on the tow vehicle.
I believe you should have a 2 5/16" ball. The hitch has a pronounced cup at the forward end. When hitching, you may have to nudge the TV forward to get it to seat. It is the reverse when trying to unhitch. The ball is binding on the front part of the hitch. When jacking it up, the TV is rising also. The solution that works for me is to jack up to where it is starting to lift, then nudge the TV back about an inch and the ball will dislodge. These hitches are a real pain. In the 11 years I have used it, this recipe has worked the best.
If you have a backup camera, I have one other pointer to offer. Our hitch is all black and it is difficult to distinguish the hitch and the frame when aligning from a distance. I painted the front 3" of the hitch at first red, then white which is much more visible. I have done this with the three trailers we own. I can see that white in the camera from 50 ft. Attached is a picture when the front tip was red.
08-11-2017, 03:27 PM
#26
Originally Posted by pbadyrka
Pretty sure we do all that. We had no trouble with our MiniLite but this new trailer has been a problem from day one. We'll be hitching up in the morning and probably won't be unhitching for 2 days(heading to Crater Lake). If we still have trouble I'll post again. Thanks for the advice. BTW-not impressed with the Cherokee. Everything is made of cheap plastic. Doors held in by tiny screws that we have had to replace. Only our second trip in this trailer. Our Rockwood was so much better, just too small.
I have a hitch on my boat trailer that has a lip at the front bottom. It is built to hook the ball and keep it from popping off inadvertently. I don['t like it either, it is a PITA to disconnect.
Try blocking your camper tires and putting the truck in reverse, then setting the parking brake on the truck. This will move the truck aft just slightly and push the ball behind the lip. Then you can use the camper tongue jack to raise it off of the ball.
Works for me, hope it helps.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
08-11-2017, 05:41 PM
#27
There should be an adjustment nut under the tongue, it may be set too tight.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
08-11-2017, 06:15 PM
#28
Solved our problem by changing the angle on the ball. Most, if not all ball angles are adjustable. I solved my problem with a slight tilt away from the tow vehicle (toward the trailer). Also, if the tow vehicle is setting at a different angle than the trailer, that can create the same problem.
08-11-2017, 06:51 PM
#29
We were at our dealer when a transporter came in with a new trailer. I helped her unhook, asked what the duct tape on the hitch was for. She said it makes it easier to see the hitch in her backup camera. She took it off as she finished her unhitch job. Said she just forgot it at the factory after she got hooked up, usually takes it off before leaving.
A note: She was driving a 2011 Duramax with 500K on it, said they have 3 of them, 2011,12,13, love em. Her, husband and hired driver deliver campers for a living.
We love camping in our Shockwave!
2016 t28FQDX Shockwave,
New Provider tires 10/31/18 ,
2021 Chev LT 3500
2020 Polaris RZR 900 Fox Edition
08-11-2017, 08:19 PM
#30
Well, the Cherokee is an entry-level stick and tin TT, compared to the mid-level aluminum/filon Rockwood line.
Sure some Rockwoods have issues, but our Rockwood had just minor quality issues.
08-12-2017, 06:02 AM
#31
You have it right. Lock the trailer with chocks or whatever you have to keep it from rolling in either direction and move the vehicle either forward or backward depending on how the vehicle rolled after you stopped. The problem you are having is this trailer is heavier than your last and as such puts more pressure on the sides of the ball if not centered. Do this and it will crank right off. There is nothing mechanically wrong with your ball or hitch it's just getting everything centered.
Richard Charron
Zephyrhills, FL
2015 Ford F150 Eco Boost
2016 Coachmen Chaparral Lite 29MKS
08-12-2017, 09:01 AM
#32
Originally Posted by Canadiancrew
Use your tongue Jack to raise the trailer so there is no more weight on the truck. Chock your trailer wheels and put the truck in gear. Nudge the truck forward so the ball will be tight against the front of the ball socket. Set the parking brake so the truck does not roll back and put it in park. Continue to use your tongue Jack to lift the trailer off the ball. Works for me every time.
Canadiancrew Nailed It !!!
We used to have to do this because of the sloop of our driveway !!!
08-12-2017, 10:06 AM
#33
Original poster never commented on using the wrong diameter ball.. interesting. Could be dangerous..
Clint...
2015 F350 4x4 gasser.. 2017 Rockwood 2506S TT
Ardenvoir, Washington (near Wenatchee)
08-12-2017, 10:16 AM
#34
Noted that as well.....
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
08-12-2017, 10:17 AM
#35
WEll...................if the ball was too small he would not have any trouble getting it off, would he?
On the other hand if it was too big, he would have NEVER gotten it together
I think it is a moot point!
