Originally Posted by Cherokee274
Hi does the 2017 cherokee274dbh had a battery charging automatic shutoff if battery is full charge
Originally Posted by bikendan
If you mean the converter, then yes, it will charge until the battery is fully charged.
Suggest that you Google "the 12 Volt Side of Life" to understand how the two different electrical systems work in a RV.
Perhaps a technicality but converters do not usually "shut off" when battery is fully charged. They switch to a "float mode", usually around 13.25 volts, which now maintains the battery against the normal self discharge as well as any accessory draw like LPG/CO detector, etc.
Shutting off when battery is fully charged is not the case with the commonly used converters. Perhaps some specialty converters do.
At one time there were "automatic" battery chargers that did actually shut off but they had only two states----ON-----or -----OFF. Lots of pulsed electricity in the system which was not only annoying but could create issues with sensitive electronics. Newer multi-stage chargers are more the norm today.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
