Old 12-04-2020, 02:20 PM   #1
Battery disconnect? yes or no
First year w/a tt, cherokee 274RK and we LOVE it. So I winterized a few weeks ago. It's parked, not plugged in, battery removed and stored in my basement for the winter, propane turned off. I went to show my visiting kid and plugged it into my TV but went inside and still had no lights until I plugged in the battery disconnect near the fuse panel. So my questions: 1. Did I really need to be plugged into my truck to get any lights or would they work from the factory solar panel without plugging into my truck? 2. Can I leave the battery disconnect plugged in for the winter? Does it hurt anything? Or should I unplug it?
Thanks for any help you guys can give!
Dale
2021 Cherokee 274RK towed by:
2020 GMC 2500HD AT4 w/Duramax 6.6 Diesel
Fastway e2 Equalizer Hitch
dwilli1 is offline   Reply With Quote
Old 12-04-2020, 02:52 PM   #2
Always Learning
The solar panels are there to charge the battery.
The RV lights and whatnot run off of the battery (or alternative power source such as being plugged into the truck or being plugged into 120v power where the converter makes 12v).
1, You need that power source for the lights to work (batter/truck/120v).
2, Shouldn't matter since there isn't a battery.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 12-05-2020, 09:40 AM   #3
SeaDog's Avatar
I agree with ependydad, but have to ask if you have a solar panel to keep the batteries charged why are you removing them for the winter?
Retired Navy
2016 Flagstaff 26 FKWS
Old 12-05-2020, 04:19 PM   #4
Thanks for the replies...obviously had a brain fart. I KNEW the solar panel charged the battery; not sure what I was thinking. It seemed like more lights came on when I re-plugged the disconnect while my truck was plugged into it but I was looking down and maybe was wrong, other than the panel showing 13.6V.
SeaDog: because I live in NE PA where it can get below 0 degrees, often below 10. I always keep batteries (boat, rv, etc) in my basement in winter, throw them on a trickle charge every 6 weeks or so.
Old 12-05-2020, 04:27 PM   #5
U.S.ArmyVeteran's Avatar
Dale
"plugged in the battery disconnect near the fuse panel."
Curious as to what type of disconnect you have and where it is located?
U.S.ArmyVeteran is offline   Reply With Quote
Old 12-06-2020, 03:31 PM   #6
n0ms's Avatar
My MPPT solar controller needs to be hooked to the battery to wake up. If the batteries are dead it needs to see 12v to start charging. ( Like from the 7 pin truck plug. )
You should also unhook the solar panels first, before removing the batteries.
n0ms is offline   Reply With Quote
Old 12-06-2020, 05:11 PM   #7
Our first Winter with our new TT was last year and we did remove our batteries and keep them on battery tenders until we started our season. We did not explicitly disconnect our solar panel and I can't conceive of a reason to do so, however, the connect from the panels (most likely the charge controller) is made at the battery terminals, so we effectively disconnected the panels when we removed the batteries for the winter. It was just a consequence of the removal, however, so I'm curious as to the reason for your admonition.
Forest River Flagstaff e-pro 14fk
Ford Escape Turbo
Sarahcat is offline   Reply With Quote
Old 12-06-2020, 05:46 PM   #8
Adrian Gordon's Avatar
A fully charged deep discharge battery should be able to get down to about -90 F without freezing.
https://www.godownsize.com/rv-battery-freeze/
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
Adrian Gordon is offline   Reply With Quote
Old 12-06-2020, 05:51 PM   #9
X2
No need to remove them to keep them warm or connected to a tender.
Fully charge, totally disconnect and you are good.
Days Camped: '18=51 '19=58 '20=110 '21=15
Old 12-06-2020, 06:02 PM   #10
SailorSam20500's Avatar
T
Putting your batteries in your warm basement is why you need to recharge them. A fully charged lead/acid battery won't freeze until temp is somewhere below -60°F. According to the US Army COE:
"Batteries should be stored in a cold place, say, about -15°C, although when fully charged to a specific gravity of 1.280 or greater they can be stored at -1°C indefinitely without deteriorating. .... In addition, all batteries experience some degree of self-discharge during storage. This can be greatly reduced by storing them at lower temperatures."
For your reading pleasure: https://armypubs.army.mil/epubs/DR_p...web/r740_1.pdf
Al
Save the Earth. It’s the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 12-06-2020, 06:45 PM   #11
I leave the solar connected to the battery and the disconnect switch "off" when in winter storage. So far, as long as I keep the water level up in the battery it has functioned just fine. Turn the switch "on" and have lights as needed with the installed gauge reading between 13.6 and 12.5, until the switch is thrown again within a couple hours. Then it charges up again over time.
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
battery, battery disconnect
