Old 03-20-2020, 01:56 PM   #1
Black tank flush issues
I own a 2020 Grey Wolf 29BH. I have tried to use the black tank flush four times now, and it has never worked. I thought it may be the the vacuum breaker, so I removed it and put in a straight male to male coupling. Nothing. I did find out that I have a leak from the exterior connection into the camper, though. Anyone know a part number or where to get a replacement? Is anyone else having issues? What did you check/ replace. Enclosed underbelly, so I canít easily check the connection to the black tank.
2020 Grey Wolf 29BH
2015 Ford Expedition EL Platinum
RetNavy is offline   Reply With Quote
Old 03-20-2020, 02:31 PM   #2
brookstone345sa's Avatar
That leak could indicate that line from hose connection to tank is crimped. If possible I would check that first. Second would be air admittance valve, sometimes they are installed wrong
brookstone345sa is offline   Reply With Quote
Old 03-20-2020, 02:53 PM   #3
Air admittance valve/ could be under bath or kitchen sink
Old 03-20-2020, 03:36 PM   #4
2014 XLR 27HFS
dave961's Avatar
I had a similar issue when I bought ours. I too thought it was the backflush valve. I took that apart and put it together, tested fine. Next I traced the line from the side of the trailer and found the factory had zip tied a 180 degree crimp in the line. Even after removing that tie, it took some work to loosen the crimp in the line. It's worked great since then.
ID:	225463   Click image for larger version
ID:	225464   Click image for larger version
Dave & Audrey
dave961 is offline   Reply With Quote
Old 03-21-2020, 11:43 AM   #5
Thank you
Thank you for mentioning the kinked hose. I pulled down the undercarriage enclosure, and sure enough it was kinked. Now to figure out how to fix it. I moved the hose to a somewhat straighter run position, but the hose is collapsed in the area it was kinked. I’ll probably get a new section of hose and splice it in. Thanks again for everyone’s comments. I appreciate it.
Old 03-21-2020, 11:50 AM   #6
Mr. Dan's Avatar
I can't see how the air admittance valve under either sink would have any effect on the black tank and its flush. An air admittance valve under either sink affects that sink's gray tank, not the black. Right?
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 42; Booked = 36
Old 03-21-2020, 11:53 AM   #7
Originally Posted by RetNavy View Post
Thank you for mentioning the linked hose. I pulled down the undercarriage enclosure, and sure enough it was linked. Now to figure out how to fix it. I moved the hose to a somewhat straighter run position, but the hose is collapsed in the area it was linked. Iíll probably get a new section of hose and splice it in. Thanks again for everyoneís comments. I appreciate it.
Sometimes a little heat from a hair dryer at the kink and some squeezing at the wide spots of the kink can help re-shape the hose so no further intervention is needed.
I would use a hair dryer rather than heat gun as heat guns can often get hot enough to melt "plastic" items and most hoses and piping (PEX) are just various types of "plastic".
Most lines that are kinked, and re-routed will eventually straighten out if they are under pressure constantly. The flush line only has pressure in it when used so it needs a little help.
Heating/reshaping is often easier than replacing.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 03-21-2020, 12:24 PM   #8
You can use a short length of PVC pipe as a "splint" if you split it lengthwise first.
Paul Dershem is offline   Reply With Quote
Old 03-21-2020, 12:30 PM   #9
Smile Kinked hose
Thank you for mentioning the kinked hose. I pulled down the undercarriage enclosure, and sure enough it was kinked. Now to figure out how to fix it. I moved the hose to a somewhat straighter run position, but the hose is collapsed in the area it was kinked. Iíll probably get a new section of hose and splice it in. Thanks again for everyoneís comments. I appreciate it.
Just take an adjustable radiator clamp, put it around the kink and slowly tighten until kink disappears. Has worked for me several times.
VMI'62
Edmund is offline   Reply With Quote
Old 03-21-2020, 12:39 PM   #10
2014 XLR 27HFS
dave961's Avatar
To get the kink out of mine, I forced it round with vice grips and left it like that a few days. Still wanted to collapse a bit, so (not sure you can see it in the picture) I put a fat zip tie around it. I wanted to use a hose clamp like someone mentioned, but I would have had to remove one end - then deal with re-attaching it. I like the hair dryer idea.
Dave & Audrey
Old 03-21-2020, 12:47 PM   #11
bubbles's Avatar
This post should never have been part of this thread.
Old 03-21-2020, 01:12 PM   #12
Adrian Gordon's Avatar
Thanks. I thought maybe my whole understanding of my plumbing system was crazy.
2018 Coachmen Leprachaun 210RS with DW, Nanuq the Samoyd puppy and the cat.
Adrian Gordon is offline   Reply With Quote
Old 03-21-2020, 02:09 PM   #13
Listen to Edmund
Use a hair dryer or heat gun to soften the kink, then apply an appropriately-sized plastic pipe clamp (or two) from the hardware store (or radiator hose clamps from the auto parts store) to bring it slowly back to round, heating again as you work if necessary. Leave the clamp(s) in place permanently as long as they aren't rubbing against something they'd hurt. This method offers a lifetime fix, bringing the hose back to full diameter without having to cut, splice, or anything else your original hose.
GFD47 is offline   Reply With Quote
Old 03-21-2020, 02:44 PM   #14
Not sure how thatís related to a BW flush. That goes to grey water tank.
JP Camper is offline   Reply With Quote
Old 03-21-2020, 02:47 PM   #15
NMWildcat's Avatar
I did have a pex line crimp after installing our Shower Miser. It crimped due to too much tension going around a corner and the high heat of summer.
My solution was to cut out the crimp and install a 45į shark byte fitting. No more problems.
Scott and Liz - Southern NM
Old 03-21-2020, 03:27 PM   #16
That has worked for me several times too.
Also 4 or 5 zip ties next to each other wrapped around the kink and pulled as tight as the diameter of the hose often straightens the kink out.
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 03-21-2020, 04:14 PM   #17
It does not relate. That info came from someone how does understand plumbing. Water lines and drain lines are nit connected.
Old 03-22-2020, 09:02 PM   #18
i can't provide any fix for ya but i can tell you that in our new 23DBH, we too are leaking between the fitting and the interior plumbing (i.e. inside the wall).
i'm just having the dealer fix under warranty. they're fighting with forest river now regarding the repair time required (who said 20 minutes while dealer says much longer... whatever, between them i guess). i'm supposed to check back in with them in a week.
OR_Brewer is offline   Reply With Quote
black, black tank, black tank flush, flush, tank
