Originally Posted by cavie
Install a pull chain switch on the fan and install a fob extension on it. I did in my bath. I removed a partition around my pump that was in the storage compartment.
Thanks Cavie, I think I can get a wall switch for the fan. The pump access will be tricky, I think I can get to it by removing the fireplace. The patio light is no problem because the cabinet with the command center is right there.
