Old 05-22-2021, 06:51 AM   #1
Driven radio system - Clock question
I saw other Driven radio system threads, but didn't want to highjack them. My issue with the Driven radio system is the clock. You can set the clock to the current time, but it never changes. I set it yesterday to 5:09 PM, and right now, at 7:50 AM the next day, it still shows 5:09 PM.
Is there a trick to make it work?
tcaleb46 is offline   Reply With Quote
Old 05-22-2021, 07:22 AM   #2
Kanadian Kamper
kenandterry's Avatar
I’ve seen all kinds of ways to set clocks, in vehicles and at home.
How about.....
Set the time the way you have so far, then when it’s set, finish the action by pushing the “clock” button to end the operation. Some units I’ve seen done this way, will confirm the clock is actually “ticking” by flashing the colon dots on the screen. If they’re not flashing, it’s not working.
Just a thought.
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 05-22-2021, 07:58 AM   #3
Sorry, the radios do not have a "clock" button. You hold the "mode" button until the clock comes up, then hit the "mode" button again to select the hour. Use the volume up and down to set the hour, hit the "mode" button again to select the minutes, and do the same thing. That sets the time, but it does nothing after that.
How about.....
Just a thought.
Old 05-22-2021, 02:30 PM   #4
I figured that every time that I disconnect the battery switch the radio has to restart the next time I use the trailer. If this is the case then I am going to have to set the time during each of my outings. Can someone confirm this? Thanks.
TTnewbie is offline   Reply With Quote
Old 05-23-2021, 08:01 PM   #5
And then...
And then you hit the "mode" button one more time to tell it that you're done.
Larry
Larry-NC is offline   Reply With Quote
Old 05-29-2021, 03:37 PM   #6
I think I did, but I will try it again.
Old 05-30-2021, 08:31 PM   #7
Nope, when I hit the mode button again after the minutes, it just went back to the hour setting. I held the mode button down to end the setting, but it did not change the time at all after that.
lock, question, radio
